Results 1 to 3 of 3
Thread: Accessory outlets
    Jul 2018
    Indiana
    30
    Accessory outlets
    I was working on the white big red and was thinking of adapting the front accessory plug to a modern cogarette or usb plug. Then I thought it might be better in the tool box. Once I started looking at that I noticed my right side tail light plug looks like it has plugs for 4 wires ( pic attached). Wired some plugs on a usb cigarette lighter combo and it worked. Any thoughts. Good bod idea? Pics attached.
ID:	254884   Click image for larger version.
ID:	254885   Click image for larger version.
    Jul 2018
    TN
    1,065
    The cig plug would work. I would NOT want to use a USB port unless you wire in an inverter as well. I bought a sine wave generator for that very reason. My conventional generators would eat my Samsung TV for lunch. The variance in voltage is too much for sensitive electronics.
    Jul 2018
    Indiana
    30
    Thank you for the info sounds like I need to rethink and do some more research!
