So i picked up a pretty clean little 90. Its a '74. It runs but the carb leaks and its original. I'd like to just swap a carb on it for cheap. Been staring at ebay and found I find one that fits the original specs. The intake opening is 19mm and the air filter OD is 31mm with 48mm bolt spacing. I want it to just fit into the original air filter boot. Every one on Ebay says it fits 76-79 and seem to be mostly 22mm. It the 76-79 intake 22mm? Could I swap intake manifolds and open my options?
