Upcoming Events for the Next 120 Day(s)
Results 1 to 10 of 10
Thread: Toying around the idea of a 2 wheel conversion
    BarnBoy is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2015
    Oklahoma
    305
    Got a junk 200E frame thats been hacked up and rewelded in places. Thinking of cutting the back end off and turning it into a bike on the cheap. I have a bunch of 1x1 square tubing...about 1/8" thick. Probably going hardtail just because thats easiest. Would that size tubing be strong enough or way too light? Can do the welding myself. Anyone who has dont this before....any tips??
    Figure I could make my own axles and jack shaft and just use pillow blocks for bearings. Have access to a machine shop, so should be able to come up with something as far as a rear hub.
    Thanks
    1984 HONDA ATC200M
    Da velder
    Mexico
    7,498
    My $0.02, don’t.
    Nico Suave.... be part of something bigger
    Jun 2015
    Oklahoma
    305
    My $0.02, donít.
    Why not? The frame is basically scrap as is....
    1984 HONDA ATC200M
    Da velder
    Jul 2018
    TN
    754
    If its what you WANT then its silly to try to talk you out of it
    ....but, the return on an investment of this size is pretty small.
    I have toyed with the notion myself and resigned to just wait until i want it bad enough to buy a fat cat.
    I have a 200e frame in similar sad shape. I have it as a back burner project to make a stripped down to near nothing rigid front franken build. Should be good to absorb the surplus of parts i have that wont fit my ES's
    Amateur Resurrectionist
    Jun 2015
    Oklahoma
    305
    Quote Originally Posted by Gabriel View Post
    I mean, the way I look at it I have a junk frame,good engine, and bunch of good square tube sitting there collecting dust, and a welder. Pretty much all the pieces to slap one together. It would just be a fun toy to ride around on, and nice thing is it would be super narrow so I could fit down tight places. I think if I go hardtail I could build it pretty cheap and simple. Just looking for ideas and thoughts really. Open to any suggestions or thoughts, not set on doing it, just tossing around the idea.
    1984 HONDA ATC200M
    Da velder
    Aug 2005
    CT
    87
    Apr 2014
    Edmond, KS
    1,525
    BarnBoy, if you do make it a hardtail, then put some kind of seat with springs on it.
    Jul 2018
    TN
    754
    Quote Originally Posted by floydechoes2000 View Post
    I couldn't read past using the tecate for parts. Completely lost interest after that.
    Aug 2005
    CT
    87
    I cannot disagree with you, that one would have been easy to save. Still, I have to give the guy credit for his final product.
    Jun 2015
    Oklahoma
    305
    That's super cool! Really good engineering. Thanks!
    One more question....what do people who have done these conversions run as far as drive chains go? Stock 520 o-ring chain? Seems to me that #40 or #50 industrial chain would work too, right? I can find way more sprockets for those vs the motorcycle/ATV chains.
    1984 HONDA ATC200M
    Da velder
