Results 1 to 9 of 9
Thread: Needing help with 85 250r piston rings.
    gimmeamidget is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2014
    utah
    436
    Cylinder has fresh hone and picked up a Honda piston 66.50 to match the cylinder. I have been unable to locate a set of rings to match. Is there any other brand of rings that fit a Honda piston or is the only option to buy a wiseco or prox piston/rings set?
    ATCKevin's Avatar
    ATCKevin is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2018
    Michigan
    179
    look up the OEM part number and check ebay?
    Jun 2014
    utah
    436
    Thanks, I have been watching for a month now for either atc or trx rings but I have only seen aftermarket rings so I was hoping an aftermarket set would fit. I am sure most if not all aftermarket rings are different.
    Slidell, LA
    4,738
    Jun 2014
    utah
    436
    Thanks I will check on these. Have you used these on a Honda oem piston and they fit? I was worried they would be different.
    Slidell, LA
    4,738
    I have not. If you want to be 100% sure Wait for a set of OEM rings to pop up or get a piston and rings from wiseco. I don’t see why these wouldn’t work though.
    Jun 2014
    utah
    436
    I will give them a shot and if they dont fit right I will continue my search or go wiseco. thanks
    Aug 2016
    East of Worcester ma
    1,372
    I’ve got these- problem is the part# says one thing and the written on tape says another (old looking tape) let me know if you want to try them. Click image for larger version.
ID:	255114 Click image for larger version.
    So they could be any size/ no idea
    Shep
    Jun 2014
    utah
    436
    Shep I sent you a pm. thanks
