Thread: Help ..250 Recon engine noise
    Dec 2009
    illinois
    1,765
    I just put a another bottle end on this 2016 250 Recon.. it has a tapping noise and everything looked good and tight on the bottom end. I adjusted the valves and it's definitely not that. It did have wear on the Piston skirt and and the bottom of the cylinder, I only put new rings and Piston pin but did not bore the cylinder and just cleaned up the Piston skirt the best I could.. would this make that tapping sound? https://m.youtube.com/watch?v=_6GynSW-oL0
    6,809
    Could be piston slap , were you able to inspect the timing and oil pump chains ?
    Dec 2009
    illinois
    1,765
    Yes , the replacement bottom end had good timing/oil pump chains but I put new ones in anyway. And the crank was good and tight, no play
    Dec 2009
    illinois
    1,765
    thanks shortline10... I'm with you, it must be Piston slap due to worn cylinder/Piston... I just don't think it could be anything else.. I'm about to spend $200 on a brand new cylinder n piston.. I need to be sure before I spend any more on it
    6,809
    With that amount of noise I would think it would be obvious when you pull the top end apart and start measuring .
    The auto timing chain tensioners do go bad and they can make the same type of noise but I would pull the top end first .
    Quote Originally Posted by honda200x1987 View Post
    Dec 2009
    illinois
    1,765
    Fixed it! Runs like brand new! It was Piston slap , I installed a brand new cylinder, Piston and rings. Sounds perfect!
