Results 1 to 10 of 10
Thread: Buying my first trike .
    Nov 2018
    IN
    30
    Buying this 1984 Honda 125m this weekend. Other than painting the tank back to OEM color and a headlight its in awesome shape! IS $500 a fair price ?
    Thanks
    Soutwestern PA
    2,040
    Prices vary greatly across the country. What else do you know about it?
    Does it run? Lights work? Brakes work?
    Cosmetically it looks like the the plastics and seat are in nice shape.
    The 125's are pretty fun and actually very capable with the HiLo tranny.
    Apr 2012
    USA
    4,114
    I'd say it's a pretty good priced assuming it runs, drives etc and the rest of the machine mechanically is as good as it looks cosmetically. I've bought ugly parts machines for $250 each and that was pushing my upper limits (aka take 2 machines and make 1 good one for $500 + the work involved). Of course I got the short end of the stick, both machines have a broken boss that is part of the shifting system. Make sure it shifts easily though the gears before you buy it. Sounds to be a somewhat common problem if the shifter ever was ran into something, or the rider forced it though the gears.
    Nov 2018
    IN
    30
    I can see from the picture that I’ll need a new headlight trim ring . The owner says it works just needs a new bulb. He also says it starts on the first pull or push of the button . No smoke , will idle and runs like it should . I’ll find out Saturday about anything that might be hiding .
    Nov 2018
    IN
    30
    Thanks for the heads up on the shifting! I’ll definitely give that a good look. Do they all have this issue ? Should I consider another model like the 200cc ? I’ve done some reading about the broken Boss deal and it looks like a nightmare.
    Nov 2018
    IN
    30
    I’m in Northern Indiana on the Michigan border .
    Sent from my iPad using Tapatalk
    Apr 2012
    USA
    4,114
    The broken boss I've only seen on the 125, the 70,90,110 engines have a similar shift system though, but the shifter ratchet tooth thing breaks off and is replaceable compared to the actual case breaking. The 185+ engines use a different system to turn the shift drum, stronger design overall but if the shift lever is ran into something, the shifter part can still break, replaceable again though. The machines I bought were beat and in poor shape, so not a good sample for average machines, but I can't really comment more than that since I've never rode one around or anything.
    Apr 2014
    Edmond, KS
    2,534
    I did most of my early learning on a 1984 125M back in the early 90's. I'd still love to have a first gen 125M today.
    May 2015
    San Diego, CA
    1,743
    Quote Originally Posted by Yzfireguy815 View Post
    Thanks
    I like that little trailer in the back!
    $500 is good.
    Nov 2018
    IN
    30
    $500 is good.
    Same here ! I’m definitely going to ask about it .
