Results 1 to 9 of 9
Thread: FYI 250sx 250es shifter stuck down
    Apr 2012
    AR
    73
    Thought i would share what i found.
    Traded my Auto-X for an 85 250sx, and the foot shift would not return, it would stay down unless i pulled it up with my toes on a down shift.
    After reading on here i figured it would be the common return spring bolt or spring its self broken #20 and #21 but it wasn't.
    #21 bolt was loose and
    The gear shift arm #19 in diagram was broken and separated and cracked on the other side. So it was spread too far out to work together.
    I put a couple spot welds on it after squeezing it back to the original position. Works great now and a free fix.
    Attached Thumbnails Attached Thumbnails 20181117_222808.jpg   Screenshot_2018-11-18-00-37-00.jpg   20181117_222758.jpg   20181117_222747.jpg
    Apr 2012
    MI, USA
    2,717
    Yep I've ran into that too. Not sure what causes it, I suspect running into something with the shifter I guess.
    Apr 2012
    AR
    73
    Exactly what mine looked like
    Apr 2012
    MI, USA
    2,717
    In my case I swapped it out, I think the shaft showed wear unevenly if I recall correctly, so I assumed it was bent too. My uncle & dad did the weld fix on a TRX125 with the same problem and he rode the snot out of the machine for a good 10 years before he ended up selling it. Large full grown guy riding a TRX125 around and it took all the beating he could give it, he upgraded to a 650 rincon so the proportions were a little better lol.
    Michigan
    1,140
    MY 85 BR is doing the same thing. Can this be fixed without removing the motor?
    85 Big Red
    83 Big Red
    84 125m
    85 TRX 125
    73 ATC 70
    Apr 2012
    MI, USA
    2,717
    Yea the side cover can come off while in the frame. Drain the oil and pull the foot peg off and there's enough room to work around the area. The photo I posted was for a 250es btw.
    Apr 2012
    AR
    73
    Quote Originally Posted by hublake View Post
    Yes. I drained oil. Laid trike on its side. Take off foot peg 14mm, and left side cover 8mm. Shaft slides out easily. Check if its broke like pictured above, or spring on it broke. Or the bolt im pointing too is loose or end broken off. May need new cover gasket
    Dec 2012
    790
    Thanks for sharing Gator. I had to replace the broken spring on my '85 250ES.
    Hublake this really is an easy fix. As mentioned the left side cover comes off and you will see pretty quick what the issue is with yours. From what I remember you have to remove the small starting gear cover as well to facilitate lining up the starter reduction gears when you reassemble. As always it's a good idea to replace the gaskets while your at it so maybe have those ordered in advance.
    1985 Honda ATC 250ES
    1985 Honda ATC 250SX
    1984 Honda ATC 200M
    1983 Honda ATC 200
    1984 Honda ATC 110
    NEPA
    6,992
    Usually a child has stood on the shifter. Seen it a million times as a dealer
