Upcoming Events for the Next 120 Day(s)
Results 1 to 14 of 14
Thread: Oil Centrifuge
    Jul 2018
    TN
    689
    Oil Centrifuge
    Ok, I'm new here. I ain't been here long enough act all .....Glamyourous and raise he11 about things but I have been making a point any time I can segue into a conversation.
    CLEAN YOUR OIL CENTRIFUGE!!!!!!!!!!!!!!!!!!!
    Tore down an engine today. Look at what is in there.
    At first glance...well that's not bad...
    .............Ohh NAY NAY!!! Start scraping and putting a little solvent to it and you might be shocked at the metal shavings that just sitting in your engine. That's a heaping teaspoon full of crap littered with little metal deposits.
    Keep the machines alive people!!!! Do your maintenance!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Ok, I'm done.
    Thanks,
    †††Gabriel†††
    Amateur Resurrectionist
    Jun 2017
    Atlanta
    107
    Thanks for the reminder Gabriel! Do you replace the gasket everytime you pull off the cover with a new one or do you make your own?
    wellys88 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2015
    WA
    187
    You can coat gasket in light film of oil will stop it from sticking and tearing. If u need to take part of multiple times.
    Jul 2018
    TN
    689
    Wellys got it.
    Apr 2012
    MI, USA
    2,717
    This is new to me, is this on all Honda engines, or more for the 200 series engines? I know the 200 series doesn't have a real oil filter, just a screen. I figured there had to be something to deal with the metal flakes from the transmission wear, not sure where that part is even located though lol.
    Also, what's up with that metal ruler in the pic? It looks like it's in inches, but instead of fractions it's in 10ths, like a inches/metric hybrid setup. Neat to see it's made in Japan too. Wish the USA would just switch to the metric system, or always talk about inches in decimals instead of fractions.
    Jul 2018
    TN
    689
    Fixer, the oil centrifuge is located atop the oil pump.
    Also, that’s a machinist scale. Leftovers from my previous occupation before I took over the family business
    Basically the oil gets spun by the rotation of the engine and simple physics take over. The heavier particulars are trapped and the oil is passed through.
    With time this crap builds up and must be cleaned out. No one ever does it though. I have YET to tear down a motor that wasn’t packed full of crud.
    Scootertrash's Avatar
    Scootertrash is offline Just Too Addicted: Protecting Our Community Lord of the trike
    MN
    3,859
    Quote Originally Posted by Pierce1989 View Post
    NEVER reuse old gaskets. NEVER slobber silicone all over an old gasket in an attempt to reuse it. Gaskets are cheap. I always keep a couple of Cometic gasket sets on hand, as well as spare gaskets that need to be replaced during maintenance.
    Oil or a thin coat of grease on a gasket can extend it's service life, but they don't last forever. I prefer grease.
    Who is Q?
    Jul 2018
    TN
    689
    For things like that side cover, the pull rope assembly and the pulse rotor cover I use Permatex Aviation cement on ONE side. Assemble and give it time to dry. The take it back down and use Lucas Red and Tacky grease to seal the other side. That way I get a good seal and the gasket stays put.
    It’s a finite deal though. Every few disassembles it must be replaced. I usually let a drip or two of oil tell me when. Lol!
    Jun 2017
    Atlanta
    107
    Quote Originally Posted by Gabriel View Post
    I have 4 motors and could have used this information a long time ago! Thanks for the advice, how long do you keep the Permatex Aviation cement on for to dry before disassembling again for the grease?
    Also, do you use "Permatex 80019 Aviation Form-A-Gasket No. 3 Sealant, 4 oz." on Amazon? It says liquid so not sure if that's what you were talking about
    Jun 2009
    san dank
    3,329
    NEVER reuse old gaskets. NEVER slobber silicone all over an old gasket in an attempt to reuse it. Gaskets are cheap. I always keep a couple of Cosmetic gasket sets on hand, as well as spare gaskets that need to be replaced during maintenance.
    Yeah don`t fack up..........have some pride in yourself and your bike !
    MN
    3,859
    That's why I use grease, holds the gasket in place for assembly.
    A properly cleaned and prepped gasket surface shouldn't need any type of adhesive, unless it's called for in the factory manual,such as something like Hondabond for between crankcase halves.
    Who is Q?
    I've been greasing gaskets for 20 years...
    The only ones you do not grease are headgaskets, or 2 stroke cylinder base gaskets.
    I dimple the case surface on the 2 strokes to avoid them getting sucked in, it happens...
    WHO IS Q?? WWG1WGA!!
    86 ATC200X Flatrack ( I may not be fast but this is one FAST 200X!!
    86 ATC350X Motocross, 86 ATC452X Flatrack!!
    07 Weekend Warrior Toy Hauler
    Jun 2009
    san dank
    3,329
    A day late ......a buck short .........circumcision ........... well i guess this is growing up.........
    Apr 2012
    MI, USA
    2,717
    While digging through parts boxes, I found the same part, ironically it was cleaned! Probably one of the machines the last owner was trying to rebuild t he engine or something.
