Results 1 to 12 of 12
Thread: Cam timing.
    Jul 2018
    TN
    1,065
    Cam timing.
    Is there a degree wheel in existence for the 200cc series Honda engines?
    The cam sprocket is merely pressed on and hope for the best. This is garbage.
    The thing should have been keyed in time.
    I realize they’re tough and ready little engines but half a tooth worth of cam timing could make the difference between running and running awesome.
    I love the 200cc engines and IMHO they’re one of the best Honda ever designed but this is goof a moment on their part.
    Scootertrash's Avatar
    In the sticks
    4,628
    Not sure if it's still available. I believe there was another company that made an adjustable gear also, can't remember who right off the bat
    http://dratv.com/atatcamsp.html
    6,726
    The lower cam sprocket should line up exactly center of tooth to keyway and with a new timing chain it should be spot on .
    A few companies offered an adjustable upper cam sprocket , powroll , big Al’s .
    Or just take a stock sprocket and make your own .
    Jul 2018
    TN
    1,065
    Seems crazy to have an adjustable set up without a degree wheel though.
    You’d just pissing in the wind.
    You can use a degree wheel. You have to make an adapter to get out from the crank threads...
    If you need a sprocket oval milled out, I have a mill, easy cheesey...
    6,726
    Not rocket science just line the dots at 12 o’clock . No degree wheel needed unless your talking a high rev performance cam .
    Jul 2018
    TN
    1,065
    Shortline, I’m talking about the crank sprocket. There’s no way to index it during installation. It’s just pressed on there.
    It could perfect or partially advance or retarded.
    I’m just tearing a crank down and was thinking about how the cam drive works.
    Nothing fancy.
    Nov 2018
    NC
    87
    Parts unlimited makes an adjustable cam sprocket that fits the 200x, was looking at when I built mine. I have seen the kit for degreeing the cam at web camshafts, should be all you need.
    https://www.ebay.com/itm/Parts-Unlim...edirect=mobile
    http://www.webcamshafts.com/pages_ve...onda/1710.html
    Slidell, LA
    4,737
    Nothing fancy.
    Why would you want to index the crank sprocket? The crank is indexed from the fly wheel by the woodruff key.
    Jul 2018
    TN
    1,065
    Yes...but nothing indexes the cam drive sprocket to that.
    Obviously you’re not going be off more than a tooth because you just skip the chain up to the next closest link but you can’t more accurate than that.
    Again, Honda should have keyed the cam drive sprocket to the crank and the cam drive sprocket would also have be properly timed when the keyway is broached.
    Slidell, LA
    4,737
    Broached? I assume you mean if you shear a key? Instead of indexing the crank gear Honda engineers should have spent more time designing an external kicking mechanism that wasn’t a PITA on the 200X.
    6,726
    Yep I understand your talking about the crank sprocket alignment , I have rebuilt hundreds of 200x cranks .
    When you press the gear back on the crankshaft align the center of the sprocket tooth perfectly to the keyway .
    Nothing fancy.
