Hey y'all, need another round of help. I had the project '83 Honda ATC 200E idling perfectly earlier, then all of a sudden it cut off and now has no spark. The battery had probably been dead forever and I am pullstarting it. At first it wouldn't start because the battery negative was disconnected on accident. Connected it, and spark again and it was idling great, which was surprising considering the picture below. Then lost spark all of a sudden. I have a few questions for y'all
1. As long as the ground cable to battery is either connected to battery or frame, does the other part of the electric start system not matter? I don't plan on using it but don't know if I need to go through as well to check for connections, or if it is irrelevant as long as the excitor coil is good.
2. I put the piston right before TDC on the F mark, valves closed, and the pulse rotor is way off from the pickup coil line. I've made adjustments in the past to pickup coil by moving the base to line them up, but this cannot be adjusted like that. It's way off. Also the advancer spring does not work. So it was idling earlier and slow revving but I bet under heavy load it wouldn't work very well. Can someone walk me through fixing this? I have the service manual but it doesn't say what to do if they're way off on lining up.
Edit..3. On all my regular 200 engines, when you remove the pull start, you can turn the flywheel by hand to the left and if you miss the F or T mark for example by a little bit, you can move it back to the right. This 200E engine if you miss the F or T mark, you can't move it back to the right at all. Is this normal?
Thanks so much for any help y'all, I'm nervous to remove the bolt and hoping an explanation/walkthrough will get me going. The advancer springs or mechanism may be able to be fixed as well if I need to remove that bolt, anyone have any experience with a frozen advancer?
