My 85 350X has a Goki electric start kit. When I torque all the cover bolts the shifter binds. With the bolts loose it works perfectly. It seems to be the bolt right by the shift shaft that is the culprit. The seal doesn't seem tight. It will still shift but will stick up or down and takes help with a boot to return. It's been this way from day one. It returns fine with the bolts loose. Has anybody encountered this? Should I shave a bit of material from the seal? Thanks in advance.
