Results 1 to 15 of 20
Thread: New member from NZ. 1985 ATC250ES.
    Dec 2018
    New Zealand
    13
    Hello. New to this forum, have recently purchased 1985 ATC250 ES. It's in pretty good condition cost $200 NZ. I have so far fixed brakes front and rear, new front wheel bearings & seals, new reverse cable, front brake cable, replaced handlebars and new hand grips. Biggest issue was running extremely rich at low revs. After taking the carb off probably a dozen times and blowing every passage through with compressor, cleaning all jets I still couldn't cure it, finally figured out the internal air passage in the body of the carb for the pilot jet circuit was partially blocked with something. Gave up on carb in the end and purchased a brand new carb from china to suit a TRX300 quad ( I happen to own one of these quads also ). Carb was a direct bolt on but had to use a TRX300 throttle cable, choke cable doesn't fit either. Bike now runs perfectly. Anyway apparently I need to get my post count up to 10 before I can contribute to main forum topics. Cheers, Mark.
    22R is offline New to the board Arm chair racerNew to the board
    Apr 2013
    louisiana
    43
    Congrats and good price. I bought this 86 Big Red a year ago for 1500. The tank has a dent on each side I would like to remove but it is my 84 year old Dad's bike right now. I also have inherited 84 200s that I am fixing a few things on as well. I need to get my post count up to so enjoy and post some pics of your ride.
    22R
ID:	256863   Click image for larger version.
    Welcome! I just battled a clogged air circuit in one of those carbs recently that drove me bananas!
    Cold Lake, Alberta, Canada
    3,001
    That seems like a really cheap 250es, congrats! I'm curious that the efficient carb cleaning that you described didn't fix the problem? In my experience (or lack thereof for a 250es) using arb cleaner and blowing out all passageways usually works. What's different with these carbs that I need to know about in case I run into the same issue? Fabio, any tips?
    Trikes
    1970/71 US 90 (Aquarius Blue)
    1972/73 US 90 Green
    1977 ATC 90 w/83 110 motor (Fugly)
    1982 ATC 70
    1983 ATC 70 (Ladybug)
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    1978 Honda XL75
    Dec 2018
    New Zealand
    13
    Price was good thats for sure, its in average condition but has not had a lot of use I would say, brakes still had plenty of meat etc. I have owned 4 other trikes over the years, an ATC200, a YTM125 two stroke and two YTM200's. I will put a few pictures of bike up soon.
    Dec 2018
    New Zealand
    13
    By the way Fabio how did you manage to clear the blocked air passage in the carb?
    Honestly I just had to give it a ridiculous amount of attention with the carb cleaner, the compressed air, but my best tool for the most stubborn carburetors is a single wire bristle from a wire brush being held by mini vise grips. That's a great carburetor tool. I had the carb out and cleaned it no less than four times then rebuilt it on the fifth go and it was still fat on the bottom and wouldn't run right at all. I got really frickin frustrated (like Todd Hoffman) and sat there staring at the bike angrily for a really long time and the wheels were spinning overspeed in my head trying to wrap my mind around this machine and these symptoms. Everything it was doing wrong pointed to the air circuit being clogged, that's what kept going through my mind. It had to be that. That's when I invented the wire brush bristle tool and was determined to fix this carburetor.
    If you want to drive yourself insane, try removing and then re-installing an SX carburetor seven times. It is not a good time.
    Apr 2013
    louisiana
    43
    I have heard thst ultrasonic cleaners do well on them too
    Dec 2018
    New Zealand
    13
    Thanks for info fabio. I have tried wire brush strand, and gas torch tip cleaners, neither worked. Would like to get it solved as carb is in great condition. I may try drilling out the welch plug on side of carb for this air passage, shouldn't be hard to reseal afterwards.
    I completely forgot! I also soaked it in a carburetor dip for like five days.
    Dec 2018
    New Zealand
    13
ID:	256921Click image for larger version.
    Trying to attach pics, Attempt 1. Sorry appears they came out sideways, looks like I need to hold my phone in landscape position. Gives you a rough idea anyway. Will look into carb dip, never heard of it.
    Apr 2012
    USA
    4,114
    I spy an aftermarket plastic gas tank that looks to be in good shape. That alone should be worth most of the price you paid for the machine. Also, your rear tires on on backwards, you can swap them side to side to reverse the tread.
    I've had a bit of issues with the 250es carb too. My dad bought an ultra sonic clean, I should pull the problem carb and send it his way and see how that effects things. My problem was the opposite though, lean on the low end, or maybe an air leak on the intake boot (didn't test for the air leak).
    How much was the Chinese 300EX carb? I wonder if that would be an "upgrade" for the 250es even though it's Chinese made.
    My other 250es runs great with a cobra exhaust, no clue if it has any other mods, but it seems stock besides the exhaust.
    Feb 2016
    Stellenbosch, South Africa
    180
    Invest in a ultrasonic cleaner, you will never look back, it is 100% worth it!
    1983 Honda ATC250R
    1983 Honda ATC200E BIG RED (sold)
    1984 Honda ATC200E BIG RED
    1984 Honda ATC200X (sold)
    1985 Honda ATC70 x 2
    1985 Honda ATC250ES BIG RED
    1988 Honda ATC250ES BIG RED
    1995 Honda Frankentrike 50cc 2-stroke
    2001 Honda TRX90
    2004 Honda TRX300EX (sold)
    2008 Honda TRX250TM
    1976 Suzuki RV90M (sold)
    1967 Vespa Primavera 125
    1958 Massey Ferguson 35
    Dec 2018
    New Zealand
    13
    Gas tank is original steel in great condition ( no rust ). Having the rear tyres backwards is quite common over here, I think people have the idea that it gives them more traction when using reverse? Doesn't bother me so will leave them like that. I got the chinese carb for $60 NZ including delivery https://www.banggood.com/Carburetor-...r_warehouse=CN Hope that link works.
    It has worked faultlessly so far.
    Apr 2012
    USA
    4,114
    I never seen logic put to the reversed tires, but I can counter that logic, how often are you driving backwards xD. It would be true though, directional tires work better in one direction and not so well the opposite way.
    The only thing I was thinking of was maybe sand riding so it doesn't dig down as fast, but the lugs are not exactly super deep on those tires (I have the same set on a 250es).
    Thanks for the link, it's about $40usd, really cheap if the carb is built well. Might have to pick one up in the spring/summer time to toy with.
