Results 1 to 7 of 7
Thread: Garage floor containment mats
    Nov 2015
    Davenport iowa
    1,144
    Is anyone using a containment mat for their garage or shop floors? I'm looking into a tru contain mat.
    Any thoughts from those of you using one of these for sloppy weather?
    1974 original 90 X 2
    1974 Original 70.
    Connecticut
    1,605
    Do you have a link to what you are thinking to buy?
    Nov 2015
    Davenport iowa
    1,144
    Quote Originally Posted by sledcrazyinCT View Post
    https://www.trucontain.com/
    1974 Original 70.
    It just looks like a heavy tarp material with a foam barrier sewing in the edge you could make one for a hell of a lot less
    Scootertrash's Avatar
    In the sticks
    4,627
    What do you do once it's filled with snow/water? Drag it outside and dump it off?
    I just squeegee the water out the door or shop vac it up if it too cold outside.
    250rAL is offline Just Too Addicted Arm chair racerJust too addicted
    Sabula,IA
    618
    I've got an Autofloorguard mat. I've had it for about 5 years. It definitely has saved my floor, which was really starting to crumble from the salt. I use a shop vac to suck up the water but it holds a lot so you don't have to do it that often. I have two suggestions, if you get one. First, make sure the floor is clean before you put it down. Even a very small stone will get pushed through it when you drive over it. Stuff on top won't hurt it. Second, if it has foam around the edge, make something to carry the tire over it without compressing the foam( the foam will get crushed over time). I used 2X2s placed on either side of the foam, with a couple strips of old license plate screwed to them to hold them together. They don't have to go the full length, just where the tires go.
    __________________
    '85 ATC250R
    .030 Over Wiseco
    FMF Pipe/Answer silencer
    36PJ Keihin
    K&N
    Boyesen reeds
    Magura hydraulic clutch
    Roost Boost
    MSR bars
    OMF swingarm skid
    ITP Beadlocks
    Three Wheelin' Since '84
    Nov 2015
    Davenport iowa
    1,144
    Quote Originally Posted by big specht View Post
    Yep I have considered making one. Foam pipe insulation for the sides and a strong double sided tape . The problem with my floor is that it is pitched toward my man door, so anything I can do to contain the winter gunk so I don't have to track through it when I enter the door would be nice.
    1974 Original 70.
