Results 1 to 9 of 9
Thread: 200S wheel conversion
    Aug 2017
    Southeast pa
    9
    Looking to get rid of the steelies on my 200. I know I can swap rear hubs to 300ex/450r etc and have a set of 450r wheels in the garage. I’m more interested in swapping the front out to a 9inch wheel as well. Can I use one of those wheels and use a spacer to center the wheel? Not sure if I’d need a hub off of another trike to do so.
    Thanks!
    Aug 2017
    Southeast pa
    9
    Ttt
    6,727
    The problem is the 130mm bolt pattern , I don’t know of any maker that made a 9” wheel in 130mm
    Check eBay out for a 8” centered rim in 130mm .
    Aug 2017
    Southeast pa
    9
    What I’m thinking is buying a 1 inch 4x130-4x110 adapter that way I could run a 3/5 offset wheel. Problem with 9 inch wheels is finding a decent front tire. May have to go to a 10 inch wheel where they have this tire in 22x11x10
    Manheim, PA
    5,758
    suzuki atv used 4x130 bolt patterns 8" and 9" rims. buy a centered aluminum used rim off ebay for like a 200x, have it machined for larger bolt pattern which they can do... Bolt it on. If not AMS makes new once piece steel rims.
    6,727
    I used a 8”x7”wide x130mm rim on my 185s with a 21” tall tire . Very similar as your picture .
    Aug 2017
    Southeast pa
    9
    What size tire is that ? Hoping to keep the fat look in the front
    Carthage NY 250r rules
    2,345
    Get a 230 quadsport rear rim either gold or silver with slight fileing bolts right on.its 9 inch if you want 10 inch get 85 or 86 quadracer rear rim.I have ran this quadsport rim on my 81 250r for years Im using 82 250r front hub same bolt pattern as 185s 200s.Click image for larger version.
    250r rules
    Aug 2017
    Southeast pa
    9
    Quote Originally Posted by atc300r View Post
    Awesome thank you!
