Page 4 of 7 FirstFirst ... 2 3 4 5 6 ... LastLast
Results 46 to 60 of 105
Thread: Progressive Spring Kit for 85 250R
  1. #46
    Jan 2013
    minnesota
    5,911
    Quote Originally Posted by DDQ View Post
    I was unable to find a used fork cap so I will be drilling out and installing a schrader valve this weekend. I will report nack exactly what I use
    I found one in less than 10 seconds using google, but imo, based on the $49.95 asking price, the seller is smokin crack.
    https://www.ebay.com/itm/333072041610
  2. #47
    The Open Road
    4,729
    Sent from my SAMSUNG-SM-G890A using Tapatalk
    You got me wondering so I went and looked in a big box of spares I had....I cleaned it up just a little bit. The Schrader is straight and everything looks to have good threads
    What's your shipping address? You can have it for free if it will save you the headache of all that work and if you promise to pay it forward to someone else(PM me)
  3. #48
    DDQ's Avatar
    DDQ is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2015
    Aberdeen, NC
    414
    PM sent! Thank you so much!
    I will certainly pay it forward.
  4. #49
    The Open Road
    4,729
    Package inbound, good luck!
  5. #50
    DDQ's Avatar
    May 2015
    Aberdeen, NC
    414
    The mail man came today and made me happy. I am going to try to do the forks after work this week but they might have to wait until Saturday if I get busy.
  6. #51
    DDQ's Avatar
    May 2015
    Aberdeen, NC
    414
    I loostened the lower allen bolts then pulled the forks off. I plan to start following the manual now and hope I can finish tonight.
  7. #52
    DDQ's Avatar
    May 2015
    Aberdeen, NC
    414
    This is all the oil that came out of the right fork. The left fork was dry.
  8. #53
    DDQ's Avatar
    May 2015
    Aberdeen, NC
    414
    Apart.
    I spent 30 minutes wrestling with the snap rings.
  9. #54
    DDQ's Avatar
    May 2015
    Aberdeen, NC
    414
    Cleaned, back together and about to loctite and install the bottom allen bolt.
  10. #55
    I always replace the lower damping rod piston "ring", it's the seal... And still available.
    I only change the bushings when they are sloppy, and just to warn everyone, the Honda bushings are disappearing quick, and I haven't found them elsewhere.
    Barnett may have a suggestion on the bushings, they are just a coated bronze split bushing, I figured ANY suspension shop could get them, but I don't know...
    And if you leave it all stock, I suggest a thicker fork oil, again, let Barnett chime in because when I ask for 15wt at my local dealer, they look at me like I'm a moron; (guess they know me well)
  11. #56
    Slidell, LA
    4,737
    15? I use 20 you lightweight
  12. #57
    DDQ's Avatar
    May 2015
    Aberdeen, NC
    414
    Done!
    I went with 20 weight. I also cut one of the short oem springs in half and put them on top of the progressive springs. If it sucks after riding I'll remove them.
    Hopefully the new fork boots will be here tomorrow so I can mount them. The whole ordeal took about 2.5 hours and most of it was cleaning. I went through three cans of brake parts cleaner.
  13. #58
    HondaRidr's Avatar
    Salt Lake
    330
    I'm excited to hear your ride report on the springs. I didn't know the progressive springs were available still.
  14. #59
    Jan 2013
    minnesota
    5,911
    Done! I went with 20 weight.
    The TECATE forks only would have needed 10w for your app.
  15. #60
    DDQ's Avatar
    May 2015
    Aberdeen, NC
    414
    The best forks in the world can't help a bike that won't crank.
