Page 7 of 7 FirstFirst ... 5 6 7
Results 91 to 105 of 105
Thread: Progressive Spring Kit for 85 250R
  1. #91
    Aug 2016
    East of Worcester ma
    1,373
    Make your piece out of a wood block exactly how you’d want it and send it up to mass. I’ll cast one out of aluminum for you just for shipping cost. I’m always looking for a reason to cast something....just need a pattern to copy
    Assuming u need a 3/8 or 1/2 inch spacer or more of some kind
    Shep
  2. #92
    Dec 2011
    central oregon
    78
    If thats aluminum any wood tool (jig saw etc) will cut it nicely.
    Twin 1982 ATC200's
    1985 350X
    1985 200X
    and a bunch of 2 wheelers
  3. #93
    DDQ's Avatar
    DDQ is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2015
    Aberdeen, NC
    429
    Make your piece out of a wood block exactly how you壇 want it and send it up to mass. I値l cast one out of aluminum for you just for shipping cost. I知 always looking for a reason to cast something....just need a pattern to copy
    Shep
    Thank you for the offer shep!
    The big hole in the middle is proving to be an issue. I don't have anything that can turn that sharp, even for cutting wood.
    I do have access to plasma cutter and cutting the piece out of steel may be the best I can do.
    Sent from my SAMSUNG-SM-G890A using Tapatalk
  4. #94
    Dec 2011
    central oregon
    78
    This will cut that aluminum.https://www.harborfreight.com/32-amp...saw-69436.html
    Or get on craigslist tools section bet there is at least 5 sub 10 dollar jigsaws on there where you are!
    Twin 1982 ATC200's
    1985 350X
    1985 200X
  5. #95
    DDQ's Avatar
    May 2015
    Aberdeen, NC
    429
    I cut this with a plasma cutter and am sending it to Shep in the AM to be cast with aluminum!
  6. #96
    Aug 2016
    1,373
    I didn’t use your steel plasma one u cut I needed something a bit more smooooth. So if time allows me I’ll get this cast today. Click image for larger version.
ID:	258119 Click image for larger version.
ID:	258120 Click image for larger version.
ID:	258121 Click image for larger version.
    I’ll post pics when done.
    Shep
  7. #97
    Aug 2016
    1,373
    Well, a little clean up and I’ll get it in the mail-Click image for larger version.
ID:	258135 Click image for larger version.
ID:	258136 Click image for larger version.
ID:	258137 Click image for larger version.
    The orange one is my wood pattern, painted it so the sand wouldn’t stick as easy- and made it smoother.
    I’ll drill the 3 holes Sunday on the drill press-I just have to make a path to get to it (garage needs a cleaning)
    Shep
  8. #98
    DDQ's Avatar
    May 2015
    Aberdeen, NC
    429
    Well, a little clean up and I値l get it in the mail-Click image for larger version.
    The orange one is my wood pattern, painted it so the sand wouldn稚 stick as easy- and made it smoother.
    I値l drill the 3 holes Sunday on the drill press-I just have to make a path to get to it (garage needs a cleaning)
    Shep
    WOW!!!!!!!!!! Shep, I hate that you spent so much time on this but thank you!!! That looks so much better than the steel one I cut! My holes didn't line up quite right either...I can't wait to see it!
  9. #99
    Aug 2016
    1,373
    Done, when installing line up the black marker lines you’ll see. It fits all three ways but lines up best where marked.
    I’ll throw away your steel plate template if that’s ok? I can ship it out Monday am. It was fun doing this just pass help along to someone else sometime.
ID:	258148 Click image for larger version.
ID:	258149 Click image for larger version.
ID:	258150 Click image for larger version.
    The one single oring between the two will work as intended.
    Your welcome
    You will need a gasket between head+flange though still.
    Shep
  10. #100
    DDQ's Avatar
    May 2015
    Aberdeen, NC
    429
    Done, when installing line up the black marker lines you値l see. It fits all three ways but lines up best where marked.
    I値l throw away your steel plate template if that痴 ok? I can ship it out Monday am. It was fun doing this just pass help along to someone else sometime.
    Your welcome
    Shep
    Thank you!! Yes, throw the junk that I made away.
    I am stoked to mount it up!
  11. #101
    Dec 2011
    central oregon
    78
    Wow excellent work!!
    Twin 1982 ATC200's
    1985 350X
    1985 200X
  12. #102
    DDQ's Avatar
    May 2015
    Aberdeen, NC
    429
    Shep did an amazing job, it fits great!
  13. #103
    DDQ's Avatar
    May 2015
    Aberdeen, NC
    429
    I just spend an hour at a shoo trying to get help bleeding my rear brakes after rebuilding the master cylinder. We could not get any pressure at the end of the line and there seems to be air and fluid leaking out of the bottom of the master around the rod. How can it be leaking there? I cleaned the cyl very well and followed the manual rebuilding it
  14. #104
    Jan 2013
    minnesota
    5,911
    Its leaking past the seal in the master.
  15. #105
    DDQ's Avatar
    May 2015
    Aberdeen, NC
    429
    Just as a final update...
    I completed the build a couple weeks ago and finally did a few minutes of riding to jet the 36 pwk. I settled at 48/ 165.
    My first real ride on it will be Friday for practice at the South of the Border MX national. I am going to race it Saturday. I just want to thank Shep one more time for the hard work on the exhaust spacer and I am SO excited to have a running, riding 250!
