Results 16 to 30 of 60
Thread: ATC200 crank rebuild
    Jul 2018
    TN
    1,065
    Well......That's my junker crank I will experiment on.
    It is NOT recommended but I used an aluminum wedge and a and worked around the bearing until it popped off taking the gear (on one side) and the cam chain drive (on the other side) with it.
    I'll take this crank apart first to learn what NOT to do before taking my good one apart. Then I will reassemble the old crank parts and indicate it in true first, again...to learn what NOT to do.
    6,726
    The correct tool to remove the main crank bearings .
    Attached Thumbnails Attached Thumbnails F4ABD473-7DDF-4C96-8706-62780D0BF49F.jpeg
    Jul 2018
    TN
    1,065
    Well, there’s nothing to that oil pressure pad.
    A roll pin, a spring and the pad itself.
    I hope someone who KNOWS can explain to me EXACTLY what’s going on with it.
    Not just it’s general function but it’s complete operation.
    It’s not enough to fix things, I want to know how they work and why.
    I took a small pin punch and lightly tapped the roll pin out of the crank. The spring is not particularly stout. No real fear of it flying across the shop.
    There’s a plug that seems to be pressed into the crank. It won’t budge so I didn’t try to force it out.
    I’ll post pics later when I can get to me desktop but there’s really nothing to see.
    BarnBoy is offline Just Too Addicted Arm chair racerJust too addicted
    Jun 2015
    Oklahoma
    731
    Ah ok. Looking at a junk crank I have it hardly looks like there is room to get the splitter in there?? Can the bearings be reinstalled by heating the bearing and freezing the crank?
    1981 HONDA ATC185S - parts
    Da velder
    Feedback:
    Jun 2015
    Oklahoma
    731
    Quote Originally Posted by Gabriel View Post
    Interesting. Yeah would still be cool to see what it looks like. Did you find any junk inside there?
    Da velder
    Feedback:
    Jul 2018
    TN
    1,065
    They are tight, but not ridiculous.
    You could toss the crank in the freezer overnight and probably tap the bearing on fairly easy.
    I cut a length of heavy wall tubing that slips over the crank to press them back on.
    Getting them off with the aluminum wedge I used (bad idea and the wrong way to do it!) they were not difficult.
    Quote Originally Posted by BarnBoy View Post
    I bet they would drop right on if you did that. Shortline could probably tell you for certain. This is probably better than pressing them on I would say.
    The Open Road
    4,729
    ...... Can the bearings be reinstalled by heating the bearing and freezing the crank?
    Edit for wrong advice... See below
    I would put the bearings in the case halves and then take the case halves over the end of the crank
    That's the only way I've done it. Case halves in the oven and bearings in the freezer. They fall right in.
    6,726
    On the 200 series cranks the bearings are press fit on the crank and they slide in the cases real easy , if your talking 2 stroke motors then the main bearings are installed in the cases first .
    The Open Road
    4,729
    On the 200 series cranks the bearings are press fit on the crank and slide in the cases real easy , if your talking 2 stroke motors then the main bearings are installed in the cases first .
    I learned something new. Thanks Mike
    Same here.
    Jul 2018
    TN
    1,065
    Not to mention the cam chain drive and oil pump drive gear are pressed on after the bearings are in place.
    Scootertrash's Avatar
    In the sticks
    4,628
    The tool shortline posted is tapered to slip under the outer bearing race as you tighten the nuts evenly. This gets bearing removal started (most of the time) by lifting on the outer race to get the inner race moving. This is why you NEVER reuse a bearing that has been removed by putting a side load on one of the races.
    I typically use the hot/cold method to install bearings, as well as lubing the shaft prior to insertion *cough* . It just makes things go a little smoother.
    Work smarter not harder.
  15. #30
    In the sticks
    4,628
    Me three!
