Results 46 to 60 of 60
Thread: ATC200 crank rebuild
  1. #46
    Scootertrash's Avatar
    In the sticks
    4,628
    What does the Manual say the tolerance should be?
  2. #47
    Jul 2018
    TN
    1,065
    Manual says .05mm - .30mm which is .002-.012
    That seems like a BIG amount of variance.
    I checked it again for good measure and I can with a mild bit of force get a .003 feeler in there. That's within spec and I am going to run it.
  3. #48
    BarnBoy is offline Just Too Addicted Arm chair racerJust too addicted
    Jun 2015
    Oklahoma
    731
    I would put it in the middle of spec if it was me. 0.006" should be great.
    1981 HONDA ATC185S - parts
    Da velder
    Feedback:
  4. #49
    If I were you I'd have Glamy measure your crank.
    Jan 2013
    minnesota
    5,911
    Again, that is within spec for an ORIGINAL honda rod, and that is still on the tight side and would likely be covered under the warranty if it seized when the vehicle was new, but you seem to know best.
  6. #51
    Jul 2018
    TN
    1,065
    No I certainly don’t! Lol!!
    It does make sense to have a little more clearance. I’m just being a whiny betch about it because it’s running true as is.
    Hopefully I can put a little pressure on it and not “move it”.
    Last thing I want is to regret being lazy. Been there. Done that.
    I will see if I can get it to .005-.006 without mucking it up.
    Thanks guys.
  7. #52
    Jan 2013
    minnesota
    5,911
    [QUOTE=Gabriel;1491862]
    I will see if I can get it to .005-.006 without mucking it up.[QUOTE]
    Do you have a strong plate with a slot in it to press it apart some?
  8. #53
    Jul 2018
    TN
    1,065
    I do. I made one just for pressing it apart. I think I will set it up in the press (when i can get back to the press) with a dial indicator zeroed on the crank journal to monitor movement. Seems the safest route.
  9. #54
    ky
    88
    I realize you’ve already done the crank, but do you have pictures of your fixtures in use? How thick is the plate you made to separate the crank?
  10. #55
    Jul 2018
    TN
    1,065
    Pics on page 1
    Plate is 3/8” thick
