Thread: 250sx Swing arm play
    Feb 2019
    Missouri
    7
    Hello. New here and just picked up a 1986 250sx. It’s a little beat up and wasn’t taken care of and trying to bring it back to life and notice the swing arm has a lot of play where it meets the frame. Haven’t looked at it much but looking for somewhere to start. I’ve ordered the tool to remove the pivot bolts but that’s as far as I’ve got. What other tools/what part would need replaced to get it tight again. Thanks
    6,722
    A set of swingarm bearings and seals is needed .
    It usually takes a blind bearing puller and some heat from a torch to get them out .
    Feb 2019
    Missouri
    7
    Do you know of a good set to buy and where from. I’ve heard a few say all balls racing are decent. And would the whole rear end need to come apart to get them out?
    6,722
    I’m sure eBay or even amazon has the kits . All balls bearing kits are ok , no need to pull the rear end apart to change the swingarm bearings .
    Feb 2019
    Missouri
    7
    Just ordered a kit and we’ll see how it goes. Everything looks pretty rusty and old hopefully it’ll come apart easy. Appreciate the help
