Results 1 to 4 of 4
Thread: 85 250r fresh lower and upper rebuild ..
    Jan 2019
    US
    12
    Just rebuilt motor it had been setting 10years ,cleaned carb put rebuild kit in it starts and idles fine [pilot jet 52]main 142...When u hit the gas tho it bogs like it's running out of gas .tried different main jet still same,can adjust air screw and it has no effect either way you turn it .anybody have any wisdom of wut to do ?
    Sent from my SAMSUNG-SM-J320A using Tapatalk
    London, Ontario, Canada
    1,059
    I've seen this happen twice believe it or not. a rag was put in an airbox and missed during assembly. enough air to idle but dies above that. thats my only experience with your symptoms.hope someone has a better answer.
    Ross..
    My Rides
    -under restoration
    -Paul Turner pipe
    -+2" Westcoast
    1985 Green Tecate Sold
    My Wife's Ride
    My Kids Ride
    Jan 2019
    US
    12
    No rag in it .does the same with breather off too
    ky
    88
    Check the reeds sounds like your issue. Could be an air leak, but it would probably be idling high if it was.
