Upcoming Events for the Next 120 Day(s)
Results 1 to 3 of 3
Thread: 1980 ATC 110 Electrical Help
    Feb 2015
    indio, ca
    18
    I keep blowing bulbs, and I am stuck on the solution..... I checked the grounds all seem to be good. When I check the front bulb socket, at idle I get 11 volts ac. If I rev it, it will go all the way to 30 volts ac. any help appreciated
    5,856
    It’s a 6 volt system unregulated , meaning the bulb is your resistor .
    Try grounding from the motor and using an analog meter for testing , could be as simple as a bad ground .
    Feb 2015
    indio, ca
    18
    turned out to be a wire on the light switch came un soldered , fixed. thanks
