Results 1 to 9 of 9
Thread: 350x gearing with 20" tires
    6bt's Avatar
    6bt is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2017
    near Syracuse NY
    318
    Hi all,
    Looking to change out my whooped chain and sprockets, and go from 18" rear tires to 20". I know 22" is stock, but too much sidewall for me. Anyone care to guess what the gearing should be changed to for stock like performance, and top speed on 20" rear tires?
    Sent from my XT1254 using Tapatalk
    Manheim, PA
    5,741
    2-3 teeth smaller rear or up 1 in front.
    Sulphur Springs,Texas
    1,005
    I went with a 36 rear sprocket on mine.
    • 1985 Honda 250SX
    • 1985 Honda 350X
    • 1985 Honda 350X
    • 1986 Honda 250R
    My Feedback Link!
    devore,ca
    1,015
    I switch back and forth from 20" hole shots to a set of old spidertrax that are at least 22" or more and I don't really notice much of a difference if any at all.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
    I just went 14 38 and all seemed great....
    Jan 2013
    minnesota
    5,911
    Quote Originally Posted by 6bt View Post
    Hi all,
    The top speed with a gear ratio change is dependent on what the top speed currently is. If you know that, the new top speed can be closely calculated by simply calculating the percentage change in gear ratio then add 2 zero's in front of that number then multiply your current top speed by that number then subtract that number from your current top speed, or, calculate your old and new gear ratios then enter that info and the tire info and the trans final drive ratio into the handy dandy calculator below and it will tell you. If your finial drive ratio is 1 to 1, enter 1:1 in the trans ratio box etc.
    http://www.wallaceracing.com/gear-speed.php
    Jun 2009
    Leander TX
    2,219
    I run the 20" Dunlops from my 85 R on my stock 85X with stock gearing. It'll barely pull 6th with my fat on it on sand. No clue how fast that is. Never had 22" on it as long as I've had it. I have some stock TRX400 20" tires on it now. Same deal with gearing.
    6bt's Avatar
    Jan 2017
    near Syracuse NY
    318
    Here's an update for you guys replacing 350x chain and sprockets. I couldn't find any other sizes than 40t rear, and a 14 front is available but supposedly rubs the case saver. So stock gearing it is :-(
    I think my front sprocket was due.
    Dec 2011
    central oregon
    78
    Oh man that sprocket has at least 3 more miles left on it...way to throw money away LOL
    Twin 1982 ATC200's
    1985 350X
    1985 200X
    and a bunch of 2 wheelers
