Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 36
Thread: Removing material with a flex hone?
    Jul 2018
    TN
    1,065
    I picked up a 200X cylinder from a local guy. It was a fresh over bore 65.5mm
    Measured 2.5762-2.5765
    Ordered a new Wiseco and the piston skirt measures 2.576-2.5761 at it largest point.
    Well FACK!!!!!
    I just ordered a new a flex hone of appropriate size. I'm hoping to be able to get .002 or so worth of material out of there for proper clearance. Is this possible without screwing it up?
    THIS is what you get when you DON'T have a shop fit the piston to the bore at the same time. *sigh*
    It's always SOMETHING!!!!!
    To the best of my knowledge the hone should work fine. Obviously don't loiter in any particular spots with it.
    Jul 2018
    TN
    1,065
    I tried it with the 3 stone spring loaded one I have but it's a 220 grit stone and the stones are pretty old. It didn't do much. The flex hone I ordered is 180 grit.
    Fingers crossed.
    I'm really getting sick of these retroactive solutions to engine building. One of these days I hope to assemble one without any words that would embarrass a sailor.
    Jan 2013
    minnesota
    5,911
    Quote Originally Posted by Gabriel View Post
    And I'm hoping to find a winning lotto ticket.
    I sure hope it is a us made one with 2 arms attached.
    Highly unlikely....well actually, let's just make that a no, but on the positive side, you can just get the next size over piston if (once) you screw it up and send it out with the cylinder this time and get it bored.
    This is sometimes correct.
    It's not a "no" in my book barns, and not even unlikely. It's been done before and will be done again. Is it optimum? That's a definite no. Will it work? Most likely yes, and it would likely be fine for the long run.
    Jul 2018
    TN
    1,065
    Well, the flex hone i ordered will be here tomorrow.
    If you see a brand new 65.5mm 10.25:1 Wiseco piston for sale in the classifieds ya'll will know it didn't work. LOL!!!!!!!!!!
    Jan 2013
    minnesota
    5,911
    Yes, fabio, of course it certainly "can" be done, however, it is not possible to remove .002" with a budget hand hone and have it be perfectly true. That will simply never, ever, happen, especially if it is the single arm type of hone. Obviously it does not need to be perfectly true to simply run, but I don't see the logic of running a "substandard", untrue cylinder after going thru all the time and expense etc to r and r the cyl and piston then buy a new piston and gaskets and get the cylinder bored etc.
    Also, it will take a fair amount of time to remove that much material with a hand hone because it does not apply a lot of pressure to the cylinder walls. I removed just around .0002" from my both of my YZ465 cylinders 3 days ago with a hand hone and it took a while.
    Jan 2013
    minnesota
    5,911
    If there is no place near you that can hone it to the proper size using the proper machine, why don't you simply box it up and mail it to a place that can. I can give you the contact info for a few of them.
    Below is a video of one of the 3 main types of professional hones that can hone it out .002" and still keep the bore true. Some of these machines can also true and untrue bore, which is something a hand held hone can not do.
    https://www.youtube.com/watch?v=IuzBQlYFgXo
    Jan 2013
    minnesota
    5,911
    If you repair something properly the first time, you won't have to repair it again any time soon.
    I don't think he's planning on running the Indy 500 with it or anything.
    Jan 2013
    minnesota
    5,911
    Perhaps the Baja 500 then?
    Jul 2018
    TN
    1,065
    Only thing my azz is running is the Bierdose 12.
    Mexico
    9,011
    Well FACK!!!!!
    So what tools at you using to measure your piston and bore to 4th decimal place?
    It sucks to get old
    Jan 2013
    minnesota
    5,911
    It looks like that is either German for Beer Can or a seriously painful rectal malfunction.
    Mexico
    9,011
    What kind of tool do you think he is ?............he`s got skills !!
    Maybe a David Lee Roth signature series tape measure?
    It sucks to get old
