Results 1 to 2 of 2
Thread: 250sx hard shifting/throttle response help
    Feb 2019
    Missouri
    7
    Have an 86 sx that was pretty rough when i picked it up and trying to get it back in order it starts no problem and idles great but when taking off it bogs down a bit and wont get up and go unless you ease into the throttle and when off the throttle it sticks just enough to keep the rpms up so you have to pull it back the rest of the way. It also shifts pretty hard through the gears so i didnt know if the carb sticking would be the problem or if that would be clutch related. I've tightened the clutch adjuster screw and didn't feel a difference. Haven't experienced either problem before so would i need a carb rebuild and could that also be affecting the shifting?
    Your shifting problem could very easily be due to the throttle issue, yes. You already know the throttle is an issue so fix that first then go from there. A very likely culprit would be a throttle cable that needs to be lubricated or replaced, but that's not the only thing that could cause that.
    When you talk about "tightening the screw for the clutch", are you saying you adjusted the clutch? You don't just "tighten" it, there is a procedure to adjust it.
