Results 1 to 10 of 10
Thread: A cam that has play/slides back and forth?
    ArizonaATC is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2012
    Eastern Canada
    163
    Was tearing into the top end to take my cam out and after I got the CDI and Advance off the cam shaft I could pull it towards me with the sprocket and chain still on, is this normal?
    BarnBoy is offline Just Too Addicted Arm chair racerJust too addicted
    Jun 2015
    Oklahoma
    731
    Yes that's normal from what I've seen. Nothing keeping it tight in there.
    1981 HONDA ATC185S - parts
    Da velder
    Feedback:
    Nov 2012
    Eastern Canada
    163
    Quote Originally Posted by BarnBoy View Post
    I thought it was, but wanted to be sure because honestly it doesn't really feel right haha.
    I think last time I took a cam out on one of those 200 engines I had the same feeling but just didn't bother looking into it
    Jun 2015
    Oklahoma
    731
    Quote Originally Posted by ArizonaATC View Post
    Side to side play should be fine. Once it's all assembled it shouldn't move much. Vertical play in the cam is usually the issue with these engines, having plain aluminum bearings cast into the head. No easy fix once they're worn.
    I am boring the left cam journal in my 200M head out to install a bronze bushing. Also using a ball bearing in the advancer housing. Had 0.01" play between cam journal and head journal. Cam had actually worn more than the head journal....go figure. Anyway I have a thread here on 3WW where I've been documenting the process. Also if you search on thumpertalk you'll find a thread on a guy who did the ball bearing in the advancer housing.
    Da velder
    Feedback:
    Nov 2012
    Eastern Canada
    163
    I meant side to side yes, thanks for the help!
    Hang on guys, don't confuse each other.
    Thrust play (or in and out), perpendicular to the camshaft is probably just fine, depends on the model.
    There shouldn't be any up and down play nor have any side to side parallel play....
    Nov 2012
    Eastern Canada
    163
    we both mean in and out play lol
    Jul 2018
    TN
    1,065
    Now you sound like Glamy.
    Jan 2013
    minnesota
    5,911
    All you guys need to stop playin with your shafts.
    Jan 2013
    minnesota
    5,911
    ...cuz you might go blind.
