Results 1 to 8 of 8
Thread: 85 250r finally got the bad trailprotrailprotrailprotrailprotrailpro done.
    Jan 2019
    US
    12
    85 250r or the 282r lol.. bored 30.5 over gone through top and bottom end from frame up ...been 20 years since my last r,and it was a 86 and 85 200x
    Sent from my SAMSUNG-SM-J320A using Tapatalk
    Manheim, PA
    5,759
    30.5 over makes no sense nor does it = 282 if stock size is 66mm and nor your at 96.5mm
    a 310R is 72mm piston
    if anything your maybe 3.5mm over the stock size because a factory sleeve wouldnt allow for much more.
    Feb 2019
    Western NY
    50
    Perhaps he meant .035" over? That would put him at a 66.889mm bore.
    1987 Honda 250SX
    1987 Honda 200X
    Jan 2019
    US
    12
    I'm at a 69.5 bore max u go ...it's running pretty good but it kinda kinda citing out or sputtering lit bit till u get in higher gears ..gas line come off carb other day while zipping around and carb ran out of fuel it quit cutting out and was running like it should..why would it do that?
    Slidell, LA
    4,737
    Quote Originally Posted by slippery View Post
    I would love to help you but I can’t understand what you just typed.
    Manheim, PA
    5,759
    your no ware close to a 282cc. Can't figure it, please take it to a local shop where they will be experienced in properly looking at it
    6,727
    69.5 bore x 72 stroke = 273.1 cc
    The equation is done this way if others are interested .
    6.95 x 6.95 x 7.2 x .7854 = 271.1
    Bore x bore x stroke x .7854 = cc
    This works on any motor to measure displacement
    May 2013
    Brownsville, Tn.
    1,271
    Exactly! Thanks Mike
    * Nicholson 500 Race Bike *
