Page 2 of 2 FirstFirst 1 2
Results 16 to 18 of 18
Thread: Looking for 250 big red, 250sx HD driveshaft U-joint optiions
    Apr 2012
    USA
    4,114
    Yea I don't really know anything about the 300 model. The manual I pulled the info from was for 2wd and 4x4, saw that right I made the post. FW is just the 4x4 version, TRX300 was the 2wd version. Same wire diagrams per year it seems. Didn't know you was in Canada (we don't really see the reflectors down here). Most models should be the same for wiring though I'd think. Engine looks pretty clean. I see there's a bit of a wire mess in the front, but the main harness looks alright.
    The ATC250SX harness is pretty simple. Green is ground, black/white is the kill wire. Keep them separated to run, short together to kill. Kill switch on the handle bars would work fine for the switch. To get lights working, you jump the red & black wires where the ignition switch plugs in (2 or 3 pin connector, pretty sure it's 3).
    If you get a dash, I modify Honda switches that are still available for the atc250sx machine using the proper plug etc so it's plug and play. If I recall correctly, the wire is slightly longer than OEM. Also sell the ignition key rubber covers since the only way to get them is by buying the whole switch assembly. I take them off the 2nd/spare key to resell. I have something like 50 or so of those rubber key covers on hand if you know anyone into collecting NOS parts w\o orig packaging.
    kevin is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2011
    Manitoba
    172
    Made some progress on the sx finally installed trx swinger and am currently coming up with different options for bottom shock mount. I like using up spare parts lying around in the garage so I'm hoping to come up with a use for these.Click image for larger version.
    Starting to make up brackets hopefully I can make something come together.
    Mar 2011
    Manitoba
    172
    Well just an update have bike back together and riding it for a while now with no real issues seems to still have decent power but haven't gone too crazy in the mud. Also have a spare motor I put a gear reduction into so may swap that over at some point
    Now next project will be trying to get 300 motor in my other sx to fire up....it's only been a couple years since I last looked at it lolClick image for larger version.
ID:	263184Click image for larger version.
ID:	263185Click image for larger version.
ID:	263186Click image for larger version.
