Upcoming Events for the Next 120 Day(s)
Results 1 to 9 of 9
Thread: speedometer whoes
    Dec 2018
    fayetville nc
    33
    speedometer whoes
    i purchased a speedo drive for a 350x it is d shaped it only works when the tire spins backwards im assuming its the wrong one any help please
    gimmeamidget is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2014
    utah
    310
    Sounds like it’s for the 200x
    Dec 2018
    fayetville nc
    33
    thats what im telling the guy on ebay but he is not listening
    Ranvier is online now At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2016
    Phoenix, AZ
    295
    Is it a guy from clifton, ME?
    Dec 2018
    fayetville nc
    33
    i think he is from florida he sent me one for a 200x opposite side my mechanic said
    Feb 2013
    Ontario
    675
    Dirtcrasher has a lot of good info you should check out.
    http://www.3wheelerworld.com/showthr...ht=350x+speedo
    Sep 2016
    Phoenix, AZ
    295
    hang on, I thought the 350x drive was “d” shape.....not “b”
    Jd110's Avatar
    Jd110 is offline Just Too Addicted Arm chair racerJust too addicted
    Aug 2015
    Idaho
    628
    Dirtcrasher sure knows a lot, yes! You need a ‘d’ that mounts on the right, for a 350x? But, you got a ‘d’ that mounts on the left. That’s interesting...I won’t confuse this but I learned something here. I believe you need 250r or 350x only drive.
    Jd110's Avatar
    Aug 2015
    Idaho
    628
    speedometer whoes
    I suspect there are two ‘d’ drives for a 23.5 tire. Left or right mount. My ‘d’ drive only works on the left and will not function spinning the tire in reverse. That’s why I now believe there are two different drivers or ‘gear’ for that size tire.
    I also suspect the only way to know is a picture of the inside gear on that style.
    With help, there should be no dispute. Good luck
