Thread: 85 250r . Not holding compression..
    Jan 2019
    US
    12
    Just rebuilt motor less 5 hours on it had problem with a cylinder stud bolt was leaking antifreeze out between cap .fixed that .it runs pretty good but seems a little rich plug even looks rich air screw is about 2and,half to 3 out it just not like it was ..did compression test and it goes up to about 215 then just falls to 0 eventually. Why is it not holding ?any help would b good thanks ...
    Sent from my SAMSUNG-SM-J320A using Tapatalk
    kevin is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2011
    Manitoba
    172
    210 seems high sounds like you're guage is bad try another one
    6,726
    Agreed , sounds like the valve in your compression tester is bad .
    215 is high , should be around 180
    London, Ontario, Canada
    1,059
    A compression test only reads the pressure build up between the piston and head based on how well the rigs are sealing, it will always leak down past the rings. your motor is new and the rings may not even be set in yet. compression tester should only register the maximum obtained pressure above the piston. I think you should do a leak down test, that checks the whole crankcase for air leaks, totally different test.
    Ross..
    My Rides
    -under restoration
    -Paul Turner pipe
    -+2" Westcoast
    1985 Green Tecate Sold
    My Wife's Ride
    My Kids Ride
