Thread: Stuck front Axle of 1985 125M
    Oct 2013
    Chandler, AZ
    97
    Hello All,
    I'm attempting to tear down the front wheel and brake assembly for my 85 125M. However, I have gotten everything else disassembled, but I am stuck here.
Name:	ATC 125M axle.JPG
    Can anyone tell me how to remove the front axle from the housing/Panel?
    Also, my untrained eye thinks that these shoes are shot. Can anyone with a trained eye confirm?
Name:	ATC 125M brake shoes 2.JPG
Name:	ATC 125M brake shoes.JPG
    Much Appreciated!
    Jul 2018
    TN
    1,065
    Unless you're on a very tight budget...toss the shoes. $35 will get you front and rear at G&H discount ATV supply.
    As for the axle....try to avoid beating it although I have had to do it. Soak it liberally and repeatedly (sometimes for a few days) with a good penetrating oil like Kroil or PB blaster. You may even have to put a little heat to it. You might also try soaking it in a bath of Evaporust for a day or two. Be patient, it was put in there....it'll come out.
    ArizonaATC is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2012
    Eastern Canada
    163
    Quote Originally Posted by Gabriel View Post
    This and I wanted to add that if you beat the axle end use a block of wood on the end so you dont damage it
    Oct 2013
    Chandler, AZ
    97
    Thanks guys. I appreciate it, and I just happen to have the specific type of oil that Gabriel mentioned.
    Oct 2013
    Chandler, AZ
    97
    Success
Name:	ATC 125M axle removed.JPG
    Finally - now removed - much thanks for the suggestions
    Apr 2014
    Edmond, KS
    2,537
    That's good news.
