Results 1 to 15 of 16
Thread: 185s facelift :]
    Mar 2018
    Upstate ny
    53
    185s facelift :]
    Today we began work on the 185 thats been in pieces since we brought it home. I decided to pull the motor out of the 200s carcass i had and clean her up before i stick it in my question to all of the pros out there is whats the best method to clean all the gunk out of the cooling fins? so far ive been using brake cleaner on a rag and moving it around with a screw driver. Im not trying to go super anal on this just want it to look decent more pics to come.Click image for larger version.
    TTown, Alabama, United States
    845
    Thats what ive done in the past and then took a paintbrush and some alumabrite to make it shine like new again
    Suicide Hill Survivor
    The rides:
    1981 ATC110
    1982 ATC185
    1983 ATC185s
    1984 ATC200es
    1985 ATC200x
    When the going gets tough, the tough get sideways
    6,726
    Mineral spirits and a hard bristled tooth brush.
    Brake clean doesn’t remove grease all that well imo .
    May 2015
    San Diego, CA
    1,743
    If you have access to a pressure/power washer use phosphoric acid carefully. Good brand is home depots zep calcium, lime rust remover. Spray..let sit for a minute...spray off....repeat.
    Keep in mind I use phosphoric acid to clean cad plated fasteners by flash dipping them for like a second or 2.....then rinsing. If it sits on your fasteners too long it will remove the entire plating. Short of vapor blasting parts ($$$) this is the best home done method I've found.
    Good luck.
    Edit......I just found these pictures of my old 90...before and after.
ID:	258112 Click image for larger version.
    Mar 2018
    Upstate ny
    53
    Thanks for the input guys Unfortunetly ive had to put this project up for a little while i work on other peoples vehicle's.... Sigh
    Scootertrash's Avatar
    In the sticks
    4,628
    Quote Originally Posted by Wbeverly07 View Post
    I hear ya!
    I have three machines that belong to other people sitting here. I've already started telling people that I'm taking no more projects, I need to get some of my own stuff done.
    Mar 2018
    Upstate ny
    53
    Exactly scooter its like finally i have a few min to work on what i want then the phone starts ringing off the hook jesus lol
    Jul 2018
    TN
    1,065
    Neat little unknown trick for that pesky phone.....if you just let it ring long enough....eventually it will stop.
    Mar 2017
    Chico CA
    119
    simple green and pressure washer works great. And wire wheel on the end of a dremel works really well.
    Mar 2018
    Upstate ny
    53
    Hit a little snag yesterday got the motor in no spark :[
    So i pulled coil off primary and secondary numbers look great. So next i figured ok its gotta be ground so i wire brushed it really where the coil mounts to the frame [its the old style coil with no separate ground wire]
    Finally worked great motor started right up idled strong did everything it should. So i shut it off and again no spark :[
    So i pulled everything back apart started checking all wireing harness connections [ no cracked wires or anything] put it all back together. Spark was strong started right up ran great shut it off and started it back up several times without any issues.
    Came back out to check it again this morning no spark :[
    Pulled it all back apart cleaned the ground again put it all back together still no spark. I pulled it over 3 more times just for the hell of it and it just started sparking out of nowhere. Started it up ran great shut it off again no spark.
    I havent checked the spark advance yet but my guts telling me its gotta be somthing with a grounding problem. If anyone has any thoughts id love to hear them im getting sick of pulling this apart over and over
    Edit: looked at spark advance yesterday it was way off [i could have stuck a quarter confortably in between it] put it back within specs sure enough started right up running strong ever since! More pics to come
    Mar 2018
    Upstate ny
    53
    And just like that the plot thickens...
    Cant decide whether i should take the time and weld it up or junk the rim and start over
    Jul 2018
    TN
    1,065
    ....just put a tube in it.
    Mar 2018
    Upstate ny
    53
    I agree the tire was on there was filled with spray foam so looks like im gonna end up with a new tire and tube. The only reason i mentioned welding is rim is rusted thru in a few spots
    Apr 2014
    Edmond, KS
    2,534
    If it's rusted all the way through, then it would be a good idea to weld the holes closed. It may be time to start thinking about some aftermarket rims too. The last was only a suggestion.
    Mar 2018
    Upstate ny
    53
    The pitting in the rim was severe but it was just a couple pin holes i plugged up i put a tube in it should be ready to ride tomarrow this 185 is just to get thru the summer while i redo the original motor itll end up with nice rims in the end im hoping though lol
