1985 YTM225DX Intro
3rd aquired trike in a month.. To quote my friend "Another One?!"
Runs OK, not perfect. Maybe needs a good valve adjusting.
Drives, at least in first gear, not enough space to go much faster atm.
No air box, no battery tray, no key..., choke is broken/gone.
Frame has been repaired in at least 2 areas. seems solid enough although not pretty, but will probably be fine for whatever I end up doing with the thing.
Exhaust leaks at header-to-muffler joint, and the muffler itself is leaking at the seam.
While the rear brakes do work, there is no cable or control for the front brakes, which dont seems to work anyways..
Anyone have one of these that is being parted out?
EDIT:
Rode it once more. shifts to 1st just fine. wouldnt go into 2nd, and wouldnt go back to Neutral while running.
Smokes pretty bad under a load. I guess It will need new rings
Reason: more info
//ArrowChat Integreation Code
