Results 1 to 14 of 14
Thread: Possible key to restoring Plastics
    Dec 2009
    illinois
    1,763
    I never would have thought but it seems water is the key! I would recommend using 2000 grit sandpaper before heating up the plastic. Maybe a propane torch would work better that a heat gun but I'm no sure. I'm definitely testing this tomorrow afternoon on some old plastics I have . So, when the plastic gets real good and shiny immediately pour water of the entire section and it will stay that way. It looks legit in the video and I never heard of anyone doing it this way before. This does away with buffing so takes all the work out of it. https://youtu.be/yAu_BYXGR1Y
    Arizona
    844
    Wow, thanks for the link. The results speak for themselves. I'll have to try it.
    Scootertrash's Avatar
    In the sticks
    4,628
    That's awesome!
    Thanks for the link!
    Aug 2015
    Idaho
    777
    Good information-thanks. I’m imagining doing a bigger piece, by myself, next to a hose and a torch-maybe not a heat gun or anything electrical.
    Dec 2009
    illinois
    1,763
    Yes, I believe it's safer using a torch when water is involved and easier.
    ATCKevin's Avatar
    ATCKevin is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2018
    Michigan
    179
    I need to restore my big red plastics, sorry for the dumb question... but why do you need to heat the plastic up?
    Sep 2013
    Saskatchewan, Canada
    661
    Going to give that a try on some old plastic that I have. OP - thanks for posting.
    Feb 2019
    Western NY
    50
    That's cool! It might be like quenching hot steel to maintain a certain grain structure, but in plastic. I'm going to experiment on an old fender, first, but I need to polish the plastics on my 200x, so this would help. I wonder if you could blend sections if you were working on a large area. I can't imagine it would be easy to keep a large area glossy long enough.
    1987 Honda 250SX
    1987 Honda 200X
    Jun 2015
    stonecreek ohio usa
    654
    I'll have to do this with big spechts klt!
    Yes you do lol
    Dec 2009
    illinois
    1,763
    Well guys I had no luck with the Heat gun , all it does is get the plastic hot and warp it. I believe the propane torch is the only option , I will have to buy one. I recommend you practice on some junk plastics first before tackiling this.
    Jan 2013
    minnesota
    5,911
    A torch, can darken the color to some degree if you get it too hot, so start off lightly. If red gets slightly darker, it's not a big problem, but yellow turns to a lovely golden brown if it gets too hot, just ask me how I know.
    A heat gun can definitely work but it needs to be one that gets blazing hot so it can get just the outer surface of the plastic hot quickly before the heat penetrates thru the plastic, which is the case with some lower powered ones. Also, it's easier to heat just the surface of thick plastic than thin plastic.
    devore,ca
    1,015
    I've heated the plastics before to remove the White stress marks you get when the plastic is bent to far. Using a good heat gun works the best for me. I've never quenched it with water though.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
    Mexico
    9,011
    My experience has been to use the heat gun to remove white marks, and sandpaper and water to remove scratches.
    It sucks to get old
