Results 1 to 10 of 10
Thread: Need some help with 1983 yt125 rebuild
    Aug 2018
    Michigan,USA
    38
    So im in the process of fixing up my engine (new seals, bearings, gaskets). I have looked on bike bandit for the seals (already have everything else). Im looking at the crank seals and see 2 types listed. Is one for the wet side ( clutch) and one for dry(flywheel). Also should i put anything on them when putting them in like rtv or such. Already have yamabond 4 for the crankcase.
    Sent from my SM-J727U using Tapatalk
    Aug 2018
    Michigan,USA
    38
    Also whats a good way to lock up the flywheel and clutch to unbolt it
    Oct 2018
    Arroyo Grande
    16
    There’s a tool for this. Stand by... looking for a link.
    Aug 2018
    Michigan,USA
    38
    Quote Originally Posted by Steve G View Post
    Found the clutch holder. To lock flywheel i just stuck some rope in the cylinder to lock it up
    Oct 2018
    Arroyo Grande
    16
    Quote Originally Posted by nmarciano19 View Post
    Copy. Post photos. I dig those bikes!
    Aug 2018
    Michigan,USA
    38
    Ill Get some tommorrow. Quality wont be that good, camera on phone is broken. However i still get some pics.
    Wichita, Kansas
    1,359
    There's a clutch holder and flywheel holder when assembling everything. You can use an impact to disassemble. After the rebuild, be sure to do a leak down test. This will confirm there's no air leaks in the motor. Air leak = lean = toasted motor. Leak down test video. You can make a tester for cheap, very cheap. If I recall, the seals are installed dry. You may want to reference the manual.
    Aug 2018
    Michigan,USA
    38
    So i almost ready to get the yt back together, and it seems i hit another bump. Ive ordered new engine mount dampers, however its looking like the metal part of the damper frkm the old ones is still in there. Anyone got any tip on how to get it out.
    Wichita, Kansas
    1,359
    Unless it's worn, I'd clean it and leave it. Im also guessing your talking about the insert into the cases? Those are simply pressed in. You can tap them out.
    Aug 2018
    Michigan,USA
    38
    Quote Originally Posted by RubberSalt View Post
    Got em out. They took aome doing but new ones are in
