Results 1 to 13 of 13
Thread: Tire choice 85 bigred
    ky
    88
    I知 looking at two tire options for the big red I just bought and wanting opinions on these tires. It値l be mostly trail ridden where it痴 hard to escape the mud so I知 thinking the d930 would be best, but I like the looks of the d929 knobby tire better. Thoughts?
    https://simpletire.com/deestone-25-12-9-ds7350-tires
    https://simpletire.com/deestone-25-12.00-9-ds7325-tires
    Jun 2015
    stonecreek ohio usa
    654
    Cheng shin dimpled knobbys are really nice. They hook up really well and are price comparable.
    Aug 2005
    CT
    206
    I put a Kenda Scorpion K290 on the front of my 84 Big Red and couldn't be happier. I paid a little more that those deestones but you get what you pay for. Traction is great and I haven't had to adjust pressure in my front tire in 5 years.
    Aug 2006
    new hampshire
    914
    I’d go with the 929 those look pretty sweet
    1982 ATC 70
    1983 ATC 200E yard rat
    1984 ATC 200X
    1984 ATC 200S (X2)
    1985 ATC 70 (X2)
    1985 ATC 200S
    1985 ATC 250R
    1986 TRX 70
    1986 ATC 350X
    2004 kfx 700 XC
    2006 prarie 700 XC
    2009 Brute Force 750
    2020 CF Moto 600
    Apr 2014
    Edmond, KS
    2,535
    Quote Originally Posted by schlepp29 View Post
    I second these tires. I have a pair of C829's on the back of my 85 250ES and love them. The D929s look like the C827s that I bought for my 85 250SX, but they are four ply tires, while the C827s are two ply. It does make a difference in the way that your trike rides.
    Soutwestern PA
    2,040
    Knobbies are your best choice, by far.
    I'd also check on the Cheng Shin like Shlepp suggested. Two ply = less unsprung weight, which is helpful.
    9 times out of 10, knobby is the right choice for a trike trail tire. Those D930s look like they belong on a Blaster.
    ky
    88
    I decided to go with the c829 I’ve got two on order hope to get them soon.
    Apr 2014
    Edmond, KS
    2,535
    Be sure to let us know how you like them. When I mounted them (and the c827's on the back of a SX) they were a real SOB to get to take air. Then they took A LOT of air to bet the beads to seat (enough to make me really nervous). They seemed to need less air if I aired then up to get the beads to almost seat and then let the air back out. Once I did that a couple of times, they seemed to seat fairly easily.
    ky
    88
    Got them mounted over the weekend, I hope to get on the trails this Saturday and will report back. Do you guys run them at 2 psi like the sidewalk says?
    kevin is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2011
    Manitoba
    172
    I was too drunk to remember what my sidewalk says lol
    Jul 2018
    TN
    1,065
    Quote Originally Posted by morgan View Post
    I like to air mine up using a cloth tape measure instead of relying on just the pressure gauge. Jack up the rear end. Air one tire up to 2 or 3 PSI, whatever you want to run, then inflate/deflate the opposite side until they have the exact same circumference. This REALLY helps the machine track straight if/when you get any uneven wear.
    There has been a couple threads on here about tires for a big red. It all depends on the terrain you ride on but we like the two ply tires for there all around traction.
    Apr 2014
    Edmond, KS
    2,535
    I like to run mine at 2.5 PSI since that's all the lower my gauge will read. It's an amazing difference over 4 PSI. I think it rides like a Cadillac.
