Results 1 to 9 of 9
Thread: 1985 tecate 250
    daddy420big is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2014
    benton
    302
    1985 tecate 250
    what are good replacement rear shock for a 85 . and what hubs are out there that i can run a honda pattern .
    Jan 2013
    minnesota
    5,911
    you want to replace the original shock with an aftermarket one?
    if so, why?
    are you certain you have an 85 shock and rocker arm?
    Arizona
    844
    Unfortunately the hubs on the 84/85 are 13 spline (I believe) and difficult to find alternatives for. It seems like I've read the the Lokata or Mojavi hubs might work, but you'll have to research it. Regarding the rear shock, I've heard of people using the 01 Raptor 660, but it raises the rear end a bit. And you might have to drill out a mount larger too.
    Mar 2014
    benton
    302
    it looks to be stock rear shock . but its blown .
    Jan 2013
    minnesota
    5,911
    Quote Originally Posted by daddy420big View Post
    i would just get it rebuilt then. all the pro 3 wheel racers in the 80's used the stock shock including me, but some like jimmy white may have had it revalved for his weight and speed.
    Jun 2009
    Leander TX
    2,219
    But the 85s look soooooooo awesome with the 4x156 hubs and aluminum rims.
    Of course, you probably have a bunch of Honda rims for the trikes you ride after the T3 breaks down
    KLF 185 Bayou hubs. 85 ONLY. 4x110 bolt pattern and course splines.
    The later year Bayous have finer splines so look closely at them when buying.
    Correct:
    https://www.ebay.com/itm/New-Kawasak...EAAOSwKptckuKR
    (This is a great price BTW)
    Wrong:
    https://www.ebay.com/itm/KAWASAKI-BA...0AAOSwBjdaDMAE
    Banshee shocks are cheap and almost bolt on and work pretty well.
    I've bought good ones as cheap as $25, but you have to be patient.
    Might be worth having the stocker rebuilt and valved and sprung for you.
    Mar 2014
    benton
    302
    thanks for the info. i had a klt 110 laying around and found you that the hubs will work on it to . and i have good rims for that and tires . and yea i have a few honda tires here to . 1 st tecate i have ever owned.
    Jan 2013
    minnesota
    5,911
    Then beware of the mighty power it can unleash, cuz it's a, TECATE...The Most Powerful 3 Wheeler In The Universe!
    Wichita, Kansas
    1,359
    I'm running an inverted raptor 700 shock. I'm a fatty, it worked out well for me.
