Upcoming Events for the Next 120 Day(s)
Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 38
Thread: Trevor's ATC250R pond skimming at Pastranaland
    Gone
    3,824
    This will probably offend alot of 250R owners.
    https://youtu.be/qaHYk4jt0NU
    May 2009
    S.E. Michigan
    1,137
    I saw that the other day! I was conflicted... it was amazing how much punishment it could take and keep going, but really bummed me out that they were abusing that machine so badly. Pretty cool that the 250R was the only one that could make it.
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    Gone
    3,824
    Quote Originally Posted by wonderboy View Post
    My sentiments exactly.
    I guess it's a pretty good test of Honda reliability, albeit way past ideal usage, but he also busted a few hundred dollars worth of stuff in the process.
    It was entertaining and cringe-worthy all at once
    schlepp29 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2015
    stonecreek ohio usa
    439
    Yeah I seen it too. I thought it was pretty cool. Show the young people what a real machine is.
    Jan 2013
    minnesota
    5,759
    It was the only one to make it because they didn't have a, TECATE...The Most Powerful 3 Wheeler In The Universe, there.
    Jan 2013
    minnesota
    5,759
    Well it looks like I now have to say that there finally is one thing the honda does better than the 86 TECATE, and that is float.
    Jun 2015
    stonecreek ohio usa
    439
    Lmao! That would be cool if they did all three brands
    Las Vegas, NV.
    2,110
    Given my knowledge of Tecates, and their aversion to water, the Tecate’s stator would have been dead after the first attempt.
    Jan 2013
    minnesota
    5,759
    Actually, the TECATE bikes and the stators aren't bothered by water any more than similar bikes are. I had to do many hours of water testing on it, which included riding through a shallow river about ten gazillion times and it never died, I also unintentionally ran it into a 6" deep river after which it did finally die then turn upside down and nearly sink, so after we retrieved it I drained the oil and removed the air filter, then flipped it upside down with the spark plug out and kicked it over a few times then turned it back over and kicked it some more etc and got it started pretty easily after that.
    Jan 2013
    minnesota
    5,759
    POST CORRECTION CUZ I AIN'T GOT NO EDIT BUTTON
    "...ran it into a 6" deep river..."
    Should read:
    "...ran it into a 6' deep river..."
    Messed up your 6" measurement again Barn
    WHO IS Q?? WWG1WGA!!
    86 ATC200X Flatrack ( I may not be fast but this is one FAST 200X!!
    86 ATC350X Motocross, 86 ATC452X Flatrack!!
    07 Weekend Warrior Toy Hauler
    Jul 2018
    TN
    821
    In the South, Rednecks do this with 540 cubic inches of Alcohol injected cast iron testicular fortitude. ....I think the truck runs on alcohol too.......
    Amateur Resurrectionist
    Jan 2013
    minnesota
    5,759
    Yeah, and my ol' lady has the same problem with it.
    Las Vegas, NV.
    2,110
    Actually, the TECATE bikes and the stators aren't bothered by water any more than similar bikes are. I had to do many hours of water testing on it, which included riding through a shallow river about ten gazillion times and it never died,...
    After my friend’s ‘87 Tecate’s stator failed the first time, he started calling the stator cover “the roach motel” because, when we removed the cover, a bunch of rusty water came pouring out. So water gets in, but it doesn’t get out.
    Jan 2013
    minnesota
    5,759
    Well the fact is that at least some water can get inside the stator cover on most bikes (including the atc250r) under some conditions UNLESS they are sealed to be water proof, which none that I know of are from the factory. The factory's typically make them "water resistant", which is not the same as "water proof", and this is because they are not building submarines, and under most typical conditions, making them "water resistant" is sufficient.
    The people I know that ride their bikes thru a lot of water simply seal the cover and wire grommet so they are "water proof" to avoid any issue with that, which is obviously the intelligent thing to do.
    Since he was getting water in the cover but it was not draining out, it obviously wasn't entering from the bottom of the cover, and the only place for water to enter any stator cover that does not have a leak around the cover gasket or mounting screws, is through the wire grommet, and this wire grommet is often located closer to the top of the cover than to the bottom, therefore, he should have made certain that his cover was not warped, and if it was, he should have flattened it or gotten another one that was not warped, then he should have used a very thin coat of sealer on the gasket then put the correct type of silicone around the wire grommet, and even put gaskets on the cover screws if he rides through a lot of water or spray washes the crap out of it, and whala, no more leak guaranteed.
