Results 1 to 9 of 9
Thread: Bearing grease suggestions?
    Oct 2013
    Chandler, AZ
    79
    Hi All,
    What is your favorite grease with which to pack ATC wheel bearings?
    Thanks for the suggestions.
    Bernard
    5,978
    Marine grease .
    Jul 2018
    TN
    1,006
    Texaco Starplex EP2
    A shop I worked at a while back folded, so I absconded with a few tubes. It's the best grease I have ever used.
    Lucas Red & Tacky is pretty good stuff too. I use it quite a bit.
    Apr 2012
    MI, USA
    3,427
    Don't know what the stuff was called but if I recall correctly it was a type marine grease. It was a blue/greenish color and makes the bearings water resistant or maybe water proof for like boat trailers. My dad packed wheel bearings on a family member's trailer that had super sloppy wheel bearings and where completely dry. He used the snot out of the trailer for like 5 years with no problems. We nick named the stuff the bearing rebuilder.
    Aug 2016
    East of Worcester ma
    901
    This grease I’ve been using forever- ps2 this has got that blueish green color too. It’s basically marine grease. The problem is it doesn’t like to wash off your hands too well.
    I regret touching the tube to take this pic- crap now it’s on my phone, and the remote too maybe a little on the cat too...
    Shep
    Apr 2012
    MI, USA
    3,427
    Sounds a lot like the stuff my dad use, just nasty stuff to work with, but it works so well. I think his was a little darker/blue but looks pretty similar. I'm pretty sure it said something about waterproofing on it too. This stuff is what is used in Dow, the local huge chemical plant. Everything rusts away that lives in the plant, even vehicles that get bought brand new and only lived on the plant for 1-2 years. My dad also used a silicone spray on the under side of the cars/trucks to keep the brake lines, gas fill tube etc from rusting out instantly.
    Scootertrash's Avatar
    Scootertrash is offline Just Too Addicted: Protecting Our Community Lord of the trike
    MN
    4,016
    Marine grease .
    Yup. Good stuff. (vague Blues Brothers reference )
    Who is Q?
    Oct 2013
    Chandler, AZ
    79
    Thanks for all of the suggestions! I have some Starbrite Marine Grease on I hand from re-doing the hubs on my utility trailer. So hopefully it should work well enough. As I live in Arizona and don’t plan on submerging or riding often in muddy environments, so it may be overkill, but we’ll see how it does…
    Apr 2012
    MI, USA
    3,427
    Just my thinking, but for desert riding, thicker, or higher temp grease would probably the best because of the desert temps. I live in Michigan so we have cold winters and quite a lot of mud/moisture and such. Besides the temp, I think basically any grease should be fine for your application though.
