Results 1 to 2 of 2
Thread: 250 big red not switching gears.
    Jan 2019
    Canada
    5
    I changed the one way bearing on big red and put crank case cover back on and now the gear shifter wont move at all anyone have any ideas what's going on?
    Apr 2012
    USA
    4,114
    Sounds like something is binding with the shift lever. I'd expect it only to be a problem if you removed the left side cover, I don't recall anything on the right side that would be effected like that. Probably best thing to do is take it back apart and find when the shifter frees up and that should steer you to the general area that the issue is at.
    You didn't mess around with the secondary clutch or the clutch adjustment right? That system ties into the shifter too.
