Thread: 250sx air filter question
    Dec 2002
    SW Alabama
    763
    Ok I know if you buy a replacement foam filter (uni, moose,ect) you have to have the metal air filter core to slip it over. How about the k&n replacements? Do they fit on metal core or stand alone? I found a good air box and lid but no filter core.
    Trikes: Cagiva 200, 85? Tiger 250,(2)84 200x's , (3)86 200x's, 87 200x, (5)85 350x's, (2)86 350x's, (2)85 250r's, 86 Tecate, (3) 85 250sx's Restoring: 83 200x, 86 250sx. Too many utility trikes to list.
    6,726
    I believe The K&N doesn’t require the filter cage .
    If you ride in dusty conditions I wouldn’t recommend the K&N . Go with the Uni or factory filter and purchase a cage .
    Apr 2012
    USA
    4,114
    If I recall correctly, I have a 250ES with a uni filter with no core when I bought it. It works, but maybe floored it would suck in the filter medium. It's a machine I basically never ride so not 100% sure. My beater has a uni filter on it + metal core and it's lasted quite well.
    I've also heard K&N is not ideal for dusty conditions, they breath better, which means it filters less. I'd still run a K&N if I had a new one laying around, but for buying new I generally go with the foam style. OEM designed it that way for a reason I'm sure.
    mmiguy2103's Avatar
    mmiguy2103 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2009
    Fairport, NY
    152
    the UNI air filter I just bought for my 250sx came with a innerspring / cage to keep the filter from collapsing.
    "Advice is Free, The Right Answer will cost you"
    Apr 2012
    USA
    4,114
