Page 2 of 2 FirstFirst 1 2
Results 16 to 21 of 21
Thread: noobiest noob: 185s towing cap?
    Jan 2013
    minnesota
    5,911
    Might be something to do with the low range, doubt the brakes would be too great though lol.
    Yes, that is exactly the problem. Just imagine if i had to try and stop while towing our box van. I had someone inside to steer it and stop when I signaled them. I towed around 700 to 800 lbs a few times with the klt and it was dangerous when trying to stop while got g down a small slope, so in general, the stopping ability is what determines how much weight is safe to tow.
    Apr 2012
    USA
    4,114
    I live in the flat lands of Michigan, so I guess the max tow rating is effectively higher here because of it =).
    Jan 2013
    minnesota
    5,911
    Lol, yes, it would be.
    Aug 2015
    Idaho
    777
    In my experience, they tow and brake fine—even maxed out. Naturally, it can be difficult on certain terrain,(especially downhill) i,e- lose dirt, but on hard pack and always using the engine to assist, they do okay.
    I’ve had on bad accident with too much weight going downhill on wet grass, but jumped off and everything turned out fine, minus a bent up hitch.
    Having good tires and how the weight is distributed on the trailer is what will make the difference.
    Oct 2017
    Duluth, MN
    19
    I've towed a 10 cubic foot poly utility trailer loaded with probably around 700 lbs of gravel down the cabin road to help fix potholes. I just towed in 1st gear on my 185s and went slow and steady.
    Mar 2018
    OH
    11
    I pulled a civic around my yard with mine.
