Thread: 1982 atc185s stator help.
    Aug 2018
    Little Rock, Arkansas
    40
    I recently purchase a stator for my trike but im a little confused as to where i resolder the wire. The red post or the blue.Click image for larger version.
    6,728
    On the red , the blue is the ground and nothing goes their .
    Aug 2018
    40
    You are the man! Thanks bud.
    Apr 2012
    USA
    4,114
    Just to confirm what shortline10 said but say it in another way, the coil you have circles on is the exciter coil. The center tab (red circle) should connect to the black/red wire in the main harness. The coil internally grounds according to the wire diagram, so nothing needed on the other tab.
    The other coil is for the lighting circuit, it needs two wires soldered on it for it to work (can't see if they are soldered on or not). Colors would be Yellow and Green.
