Page 2 of 2 FirstFirst 1 2
Results 16 to 24 of 24
Thread: 84 200x cam chain jumping
    Thanks guys- I too always wondered what IIRC meant, been meaning to ask for a while....I learned something new today
    Shep
    Shep knows because HHT...
    .HE HAS TEENAGERS
    Jul 2018
    TN
    1,065
    Have any of you guys had a cam chain "jump"??
    I've never seen that happen...
    Seen a BBC tear teeth off a gear drive. Pro-Mod motor.
    Does that count?
    The Open Road
    4,729
    Yeah. Once. In an XR100. It had a broken guide so it was pretty floppy and already very worn
    I ended up rebuilding the head for the guy. Bent those tiny valves. He also bent the swingarm worse than any I've ever seen. Probably close to three inches of bend over the length of the swingarm. Point is, this machine was abused pretty badly, so it's probably rare
    Mar 2004
    13
    Got it going today by using the 3mm bolt to tighten cam chain hasn't been this easy to start in years thanks for all the help guys
    Fullsizechevy9 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2019
    Louisiana
    354
    Your welcome was probably just froze or tensioner was wore out i had that problem with mine had to use that bolt to losen it up then pull up to tighten it wasnt the best design imo it gets wore out and doesnt put as much tension as it should but alot of things wear out over 30yrs so i guess it really isnt that bad if its been working this long alot of people dont know about screwing the bolt in there to help tighten it the try to let it auto adjust and if it doesnt work end up tearing it down when it may not be neccesary
    Mexico
    9,012
    Yes on old V8 cars with nylon gears, happens when you shut the engine off, not under load. The ones I recall didn’t damage the valves.
    A buddy skipped one on a street bike that was just over a year old in the 80’s. Cause was a defective auto-tensioner.
    Funny thing is when people switch over to a manual tensioner because they don’t trust the auto units a lot of them end up over tightening them and breaking the guides and making a really big mess.
    It sucks to get old
    JacobMonster's Avatar
    JacobMonster is offline At The Back Of The Pack Arm chair racerFirst time rider
    May 2015
    Liberty, Ky
    232
    Doug, remember when I brought the 200x over and we worked on it for a weekend? The cam chain jumped on that. It's because I was missing a piece in the tensioner.
    It would run fine, then wouldn't start forever. Then after enough kicking, it would skip back into time.
    It's getting taken apart in a few weeks. I finally convinced my Dad to buy all the parts for it to get it running right, since it's his trike. Once I get my shop built, ever single timing piece is being replaced.
    Sent from my SM-J337AZ using Tapatalk
    The Open Road
    4,729
    That's true, I had forgotten about that.
    Nov 2013
    Oxford CT, New Haven County
    983
    My Yamaha jumped timing but it was because the Key way that keeps everything inline on the crank shaft broke in two... lol it wasnt to hard to fix though, just remember to tie up the timing chain with a piece of wire to keep it from falling into the case when reinstalling everything..lol If you get a new chain you may want to think about a new timing gear as well.
