Page 2 of 6 FirstFirst 1 2 3 4 ... LastLast
Results 16 to 30 of 85
Thread: 1982 200e left crankcase cover and crankshaft bolt
    Fullsizechevy9 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2019
    Louisiana
    354
    Yep the photo worked =).
    Yea if the top end is off, no reason not to use an impact. I'd say to do something to stop it and use a torque wrench to put it back on though. It's kind of like a lug nut for a car, you should have it close to spec. I've ran across too many people that thinks like 25ft/lbs is enough torque to hold a tire on (installed via 4 way).
    Ok good tapatalk makes it so easy i will be able to post pics of everything now i may start a build thread of teardowns and everything almost start to finish i was going to just get everything before i started but i cant help myself i love working on stuff and i plan on getting a good torque wrench and torquing everything to specs also thanks
    Sent from my SAMSUNG-SM-N920A using Tapatalk
    Jun 2019
    Louisiana
    354
    Quote Originally Posted by Fullsizechevy9 View Post
    Man i seen a tri shee build a banshee motor would be awesome or one of the crf450r conversions they look so good would love to do somthing like that as a build after this build is finished this stuff is addictive
    Apr 2012
    USA
    4,114
    could always slap a 600rr engine in a 3 wheeler frame and call it a death machine lol.
    https://www.youtube.com/watch?v=kvqeyxlkJp8
    Or just double the size/hp lol
    https://www.youtube.com/watch?v=4vj3qg2wtVo
    Not sure how good that kind of setup would be on a 3 wheeler though, I could see maybe the 600rr + extending the swing arm some but you'd loose good turning etc more you extend it.
    the 450r conversions come out well too.
    There's also stuff in the 2 stroke world, like the 500R engine in a 250r frame.
    https://www.youtube.com/watch?v=BRzytz_E6tw
    Jun 2019
    Louisiana
    354
    Lol 600 may be to much a big 2 stroke in a 3 wheeler frame would be nice dont have to worry about riding wheelies to long like on this bike may be my next project a big 2 stroke in a 250r frame but im getting ahead of myself 1 project at a time a guy can dream though right these things seem like they are worse than a drug addiction
    Jun 2019
    Louisiana
    354
    Those 450r conversions look so good i like the modern look i dont race or mx so im sure it would handle good for what i like to do i just enjoy riding but they cost an arm and a leg to do
    Apr 2012
    USA
    4,114
    Yep, that's why I stuck with a 350x lol.
    I have a kawa 350 big horn 2 stroke enduro motor that I'd like to throw in a 3 wheeler frame (200x, 350x, or 250r), just haven't ran across a rolller or parts machine yet. I don't need the biggest hp or anything, just something fun to ride =). 200 was a bit too small for me, I had 2 200x's and ended up selling them in favor of the 350x. I kind of viewed it as my 250sx was almost as fast as the 200x, and it's shaft drive, so mud etc isn't a problem. Wish there was more sport models made as shaft drive. They might be heavier, but not dealing with a chain would be nice.
    I don't think I have a spare frame for a 250es/sx, but another interesting build could be to throw a TRX350D engine in one of those frames. The bottom end is very similar to the 250es/sx engines, but the top end is much like the 350x. I have one of those quads just because of the top end design. It's heavy as hell, but does ok, huge difference from a 350x. 350x is typically described as it does exactly what you tell it to do, extremely controllable etc. The TRX350D is described as a tank, it steers like a tank (horrible turning radius), it's heavy as can be like a tank, heck it even rides like a tank lol. It's a true work horse full time 4x4. One I have has a bent front swing arm or frame, so could be a fun build to swap it in a 3 wheeler frame.
    Jun 2019
    Louisiana
    354
    Yes thats all i want dont need the biggest motor possible just somthing that is fun and possibly stand up on command lol wheelies are always fun about a 350 or 450 with reverse would be nice def want to do a 2 stroke build love the 2 strokes love the way they sound smoke and everything love the look of the expansion chambers got to have a good 2 stroke in the collection
    Apr 2012
    USA
    4,114
    The 200x's I rode didn't do wheelies as well as I hoped, but maybe the ones I rode were worn out junkers or something (I've rode 4 machines). They all felt too high geared, first gear barely gets the front wheel up. I did better wheelies on my 200ES popping it in gear. Both my 350x's wheelie 1st-4th pretty much at command. It's been a while since I've rode my 250sx, but I think it's 1st and 2nd it can wheelie and maybe 3rd if you rev it and pop it in gear. My cousin's 250sx wheelies like crazy though, but it has a 250es rear diff, so lower geared.
    I'd wonder if the the china 230cc Honda clone engine cylinder would fit on an atc200x, turning it into a 230cc would help make some more power + the typical mods, higher compression piston etc. Who knows if the cylinder is much of any good, they are something like $75 new from china though.
    I looked up the specs for the 250es/sx vs the trx350d and the hp difference is a bit, but the torque is much different.
    250ES/SX
    ~18HP
    13.7 ft/lbs of torque
    TRX350D (I suspect similar specs for the 350x, but none posted in the service manual)
    24.5HP
    21 ft/lbs of torque
    While I'm posting service manual based specs, here's the first gen 200x
    ~18HP
    12.3 ft/lbs of torque
    Jun 2019
    Louisiana
    354
    250ES/SX
    ~18HP
    24.5HP
    21 ft/lbs of torque
    ~18HP
    My 200s will pop up good in first and second i have to lean back when i hit the throttle to get it up and theres no getting it up in 3rd even throwing my weight back.while laying in the throttle. Does the yfz450 quads have reverse that seems like it would be a good powerplant for a build or possibly even a 4 to 3 conversion
    Apr 2014
    Edmond, KS
    2,537
    Oh no! These aren't illegal like a drug addiction!
    Jun 2019
    Louisiana
    354
    Lol they will sure drain your wallet like one
    Apr 2012
    USA
    4,114
    Oh yea, the 3 wheelers are like a drug addiction, but it's more of a bug, once you catch it, it's hard to get rid of it. Before you know it, you have all storage areas filled with 3 wheelers and you're still looking for more.
    Jun 2019
    Louisiana
    354
    Just cant get enough working on them is just as fun as riding them knowing your the reason it runs as good as it does all while having a blast riding it is a good feeling
    Jun 2019
    Louisiana
    354
    Was thinking maybe a z400 as a powerplant dont know much about them but they do have reverse and are chain driven
  15. #30
    Apr 2012
    USA
    4,114
    Are you able to kick a z400 (or 400z whichever way it is)? My aunt's boyfriend bought the z400 motorcycle new and bought it out to my mom & dad's place to break it in since they are from the city. Kick start only, and the guy couldn't kick start it to save his life. Not that he was small or weak or anything, not sure why he just couldn't get it going on his own. My dad had no problem. I couldn't start it either, but I was like 14? I didn't grow up on 2 wheels, so can't really comment on the power, but it seems to have plenty of compression lol. There was also a quad made with the same engine from my understanding.
    The owner of the bike took it out back and got in some light mud, he goosed it too much and flew off the back and burned the inside of his leg on the exhaust, he ended up selling it as just someone taking over the payments lol. I think it was like $8k.
