Results 1 to 3 of 3
Thread: Brake fluid disappeared
    Sabula,IA
    601
    I got my 250R out a few weeks ago for a ride. It hadn't been ridden for two years. I quickly discovered that I had no rear brakes. When I got home, I took the lid off the reservoir and found it bone dry. There wasn't even an oily film in the bottom. There were no leaks apparent, even after refilling. The brakes now work fine and still no leaks. The pads are barely worn. Where did the fluid go?
    __________________
    '85 ATC250R
    .030 Over Wiseco
    FMF Pipe/Answer silencer
    36PJ Keihin
    K&N
    Boyesen reeds
    Magura hydraulic clutch
    Roost Boost
    MSR bars
    OMF swingarm skid
    ITP Beadlocks
    Three Wheelin' Since '84
    5,902
    The common place for them to leak is at the parking brake shaft o-ring .
    Jan 2013
    minnesota
    5,916
    It leaked out.
