Thread: Piston wrist pin plugs
    Nov 2015
    Davenport iowa
    1,144
    Tore into a 90 motor we picked up, pulled the top end, found a sleeved cylinder and the Piston had plugs in the wrist pin holes instead of clips. What brand of Piston is this?
    1974 original 90 X 2
    1974 Original 70.
    6,727
    Powroll used the nylon plugs
    Jul 2018
    TN
    1,065
    Teflon plugs were pretty popular for air cooled VW builders back in the day too. Seen them in those engines more than once.
    Oiled teflon would last a very long time so it's not a bad idea. Certainly easier to assemble than those GD ring clips.
    Mexico
    9,011
    Teflon plugs can be used in pretty much any 4 stroke piston, you just need to get the right diameter and length.
    They are (were?) popular for drag bike engines that had to be torn down often, but they can leave a residue on the cylinder that some people feel affects ring sealing, so they aren’t as popular for engines that aren’t opened up a lot.
    It sucks to get old
    efhondakid's Avatar
    efhondakid is offline At The Back Of The Pack Arm chair racerFirst time rider
    Feb 2015
    Canton Ohio
    203
    Another one for Powroll using them, my old mans Powroll’d XL250 uses them.
    2 in the back, 1 in the front.
    Nov 2015
    Davenport iowa
    1,144
    I like learning something new..
    So this thing had a +6 oversized piston, had been resleeved obviousley. Had a hi/lo delete case, a ported head espessially the exhaust port (oops), had a stock cam and stock crank. Was hoping for a stroker beings whoever did the work had to split the cases for the delete case half. We have not tore the head apart to evaluate for heavy duty springs. The thing had no compression, fluid running out the exhaust port.. At this point we are hoping the piston, rings and cylinder are all within specs, fix the head and leave it be.
    1974 Original 70.
