Thread: 85 250sx - carb with no pilot screw?
    May 2008
    Blackstock, Ontario, Canada
    89
    Just picked up another 250sx that has seen better days. Have cleaned the carb and am surprised at the lack of a pilot screw. This is a first for me. Rebuilt my other sx and es carbs, and a few fourtrax carbs, all with pilot screws. It appears to still be a qa02a. Has anyone seen this before? I couldn't find anything after an hour of searching.
    Attached Thumbnails Attached Thumbnails 20190808_104926.jpg   20190808_104913.jpg
    Apr 2014
    Edmond, KS
    2,537
    Is it possible that you have to remove the plug at the engine side of the carb bowl where the pilot screw usually is?
    Aug 2005
    CT
    206
    Yep, should be under that plug. He careful drilling it, don't ask me how I know.
    May 2008
    89
    Thanks for the replies guys. If there was a screw under there though it wouldn't be like the other carbs I've seen...Click image for larger version.
    6,727
    My guess is that is a replacement carburetor from the mid to late 2000’s when the carburetor was still available from Honda .
    That’s about the time I started seeing those caps over the air fuel mix screw .
    Aug 2005
    CT
    206
    It's not under here?
