Results 1 to 15 of 29
Thread: JSC 110 build thread
    Nov 2015
    Davenport iowa
    1,144
ID:	259713 Click image for larger version.
    Starting another build. Just got this back from powder coating. Motor will be a long rod h&s stroker .. will post more pics as the project progresses. This will be replacing our Nicholson's (Waterloo) trike.
    1974 original 90 X 2
    1974 Original 70.
    Pekin IL
    529
    Nice, I have always liked the look of those frames.
    Sent from my moto x4 using Tapatalk
    1985 250r
    1985 200s
    1984 200x
    bandito x2
    1979 atc70
    Trikefest 2012,13,14,15
    May 2013
    Brownsville, Tn.
    1,271
    Quote Originally Posted by hippyplz View Post
    X2 I like those as well. I almost bought one for my bike back in the day. Look forward to seeing this build.
    * Nicholson 500 Race Bike *
    Nov 2015
    Davenport iowa
    1,144
    Got a roller,
ID:	259766Click image for larger version.
    Not sure that the 110 motors fit these front mounts, does anybody know if the JSC OEM frames were made for the 90 or 110 motors? May need to fabricate new mounts.
    1974 Original 70.
    May 2013
    Brownsville, Tn.
    1,271
    Should be able to just change your front motor mount from a 110 to a 90.
    Nov 2015
    Davenport iowa
    1,144
    Hey hippyplz I see you are not to far from us, we are in Davenport.
    1974 Original 70.
    Aug 2010
    SoCal
    43
    Always like seeing these 90/110 builds. Keep us posted with the builds.
    Pekin IL
    529
    Quote Originally Posted by DAM shop View Post
    Yes sir, down by Peoria, DAM near neighbors .
    1985 250r
    1985 200s
    1984 200x
    bandito x2
    1979 atc70
    Pekin IL
    529
    You make any progress on this one?
    1985 250r
    1985 200s
    1984 200x
    bandito x2
    1979 atc70
    Nov 2015
    Davenport iowa
    1,144
    Nope,
    still at the same roadblock waiting for the motor to come back from my machine guy.. Unfortunetley for us I told him when I dropped it off I was in no big hurry. We are finishing with another one that we are going to sell. A slightly built 90 motor sitting on a nicholson frame..
    1974 Original 70.
    Nov 2015
    Davenport iowa
    1,144
    Update on this build..
    So I got a call fom my guy who was working on the motor for us.. Let me first start off by explaining why this motor was back into his shop not long after the original head work and bore.. When we first got the parts back we assembled the motor, fired it up and broke in the rings. What happened was hours into the test and tuning the trike shut down. The lack of compression among other things told us we broke something in the top end.. We disassembled the top end to find that one of the guides had broke and the valve had slapped the piston.. Assuming our guy didn't give us enough deck clearance back to the shop it went.
    On to today, (Roger) our machine guy told me that he mocked up the motor and used clay to see what kind of valve to piston pocket clearance we had, low and behold he said we have more than enough clearance and that the valve slapping the piston was not caused by a lack of clearance. So, we have concluded that A. something got sucked into the intake. B. a valve keeper came off, C. The valve guide broke for what ever reason causing the malfuction.. The good thing is that there was no serious damge to the piston or head all of that was reapairable. We will try again in the next few weeks and see what happens. Will keep the post going once we drop the motor back in. stay tuned.
    1974 Original 70.
    Nov 2015
    Davenport iowa
    1,144
    Finally got back to this build. After having a no spark issue yesterday we slept on it and found the points were grounding out. Preliminary start up went well. Sounds like this will have plenty of power, the 24mm mikuni felt just about right but will know better after a few test runs. Pretty happy with the results so far. Will be taking it in for some pinstripes and lettering in a few weeks. Stay tuned for the final results.
ID:	261188 Click image for larger version.
    1974 Original 70.
    Nov 2015
    Davenport iowa
    1,144
    Does anybody have any ideas on an aftermarket headlight bucket? Something that’s chrome, affordable with the ability to attach a guard to?
    1974 Original 70.
    Nov 2015
    Davenport iowa
    1,144
ID:	261600Click image for larger version.
ID:	261601Click image for larger version.
    Old school cool right there. Finally got back to this build to finish it up. We must have done something right from the get go on this one. Fired right up, nice idle, great power through out the hole power band. Glad to have these Bandito forks on it helps keep it grounded. Real pleased how this build went. Thanks to Jwheeler for some of the aftermarket goodies.
    1974 Original 70.
    Pekin IL
    529
    Looks fantastic!
    1985 250r
    1985 200s
    1984 200x
    bandito x2
    1979 atc70
