Results 1 to 7 of 7
Thread: I need help with a Honda 200es
    Aug 2019
    Texas
    3
    I have a 84 Honda 200es I've been trying to bring back to life. I've got it running but it bogs and backfires about half way through each gear even in neutral (basically no power in 4th). I've replaced the carb, spark plug, drained oil multiple times because it had gas in it. Anyone have any ideas of what o should do next. The atc barely smokes so I think those motor is in okay shape.
    Apr 2012
    USA
    4,114
    Could be mechanical timing (crank vs cam). First thing I think of is the carb being too lean for the main jet though, depends where the backfire is at, carb or just a misfire in the exhaust.
    Also, you running the stock CDI? Ignition timing could effect things in weird ways too. Stock CDI should be marked CI-42 (969).
    If the engine is smoking, that suggests to me the rings are getting pretty worn, normally a healthy engine doesn't have visible smoke xD.
    Aug 2019
    Texas
    3
    Thanks for the ideas. I was thinking it might have something to do with the timing because a bolt is missing for the cover from the previous owner. The backfire is in the exhaust. I also doubt it has the stock cdi because mostly all the wiring is bad and all taped together.
    6,728
    I’m betting it’s the Chinese carburetor lol .
    Buy a good used original one and rebuild it with a Shindy brand carburetor kit .
    Problem solved
    Apr 2012
    USA
    4,114
    yea the missing in the exhaust like that I'd say lean condition. Fuel flow, carb, jets, etc. Don't forget, air box with lid on is the stock jetting, removing either effects jetting. Aftermarket exhaust makes the jetting change too, same with a rusted out exhaust.
    Aug 2019
    Texas
    3
    It had the stock carb when I got it and I cleaned it multiple times. I ordered the rebuild kit but it'll take almost a month before it's here so I got the Chinese one that's on it now. It ran a little better after I changed it but still has the miss when giving it gas. It starts on the first or second pull every time and idle good. Sorry if I don't know much about them. This is my first time trying to work on any atv
    Jul 2015
    SW Oregon United States
    145
    Check out the pulse generator. See if the springs are good and that it is advancing your spark properly.
