Results 1 to 15 of 23
Thread: No spark after top end rebuild
    Fullsizechevy9 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2019
    Louisiana
    354
    Just finished rebuilding my 200s top end now i have no spark had spark before i did everything by the manual all connections are good anybody have any ideas?
    Jul 2018
    TN
    1,065
    Start with the pulse rotor. Make sure it's not 180 degrees outta time.
    Jun 2019
    Louisiana
    354
    Could my pulse rotor air gap be to wide i set it at .018 book said .015-.025
    Jun 2019
    Louisiana
    354
    Ill double check it but i did it exactly by the book flywheel on the f index mark lined the pulse rotor up with those index marks and set the air gap
    Jun 2019
    Louisiana
    354
    I do remember before i took it apart i lined up the f index mark and the pulse rotor was ahead of the index mark a little and ran good
    Jun 2019
    Louisiana
    354
    Im going to open it up and double check the timing and cdi did it by the book but obviously somthi g isnt right it had fire before no way somthing quit working that fast
    Apr 2014
    Edmond, KS
    2,535
    Try removing the spark plug cap from the plug wire. Trim 1/4" or so off the end of the wire and put the cap back on. Sometimes the end of the wire gets worn and you can't screw the cap back on and have a good connection.
    Jun 2019
    Louisiana
    354
    Ill try that may have to get a new wire last time i tried to get the boot off it would budge here what it looks like f index is lined up and the pulse rotor index marks are lined up
    Sent from my SAMSUNG-SM-N920A using Tapatalk
    Jun 2019
    Louisiana
    354
    Well i got it fired up un did all the connections amd re connected and boom got fire but sounds like my valves are ticking i set them .002 at tdc any advise?
    Scootertrash's Avatar
    In the sticks
    4,628
    Quote Originally Posted by Fullsizechevy9 View Post
    Did you try adjusting the cam chain?
    ETA: Did you remember to put that little rubber plug in the head?
    Jun 2019
    Louisiana
    354
    I put the plug in and i adjusted the cam chain has to be the valves
    Jun 2019
    Louisiana
    354
    Def valves anybody have any suggestions ill have to take the motor out to re set the valves thats what im going to try next do i need to set them at honda specs or is there dif specs on the valves for a wiseco piston i couldnt fimd anything on it i set them at .002
    Jun 2019
    Louisiana
    354
    Heres a video of the sound its a loud tick obviously coming from valve area im going to take the motor back out and see if i can get an indicator on the top of the piston and fimd tdc that way and reset the valves instead of relying on tbe index marks i think thats wjere i went wrong
    Jun 2019
    Louisiana
    354
    Here it is https://cloud.tapatalk.com/s/5d6d301c...902_095946.mp4
    6,727
    It’s as simple as putting a screw driver in the spark plug hole to find TDC , cam lobes pointed down and set the valve lash . A few degrees either way isn’t going to make a difference .
    The tick noise is probably a loose timing chain .
